NiloCK
October 13, 2018, 5:11pm
1
My internet connection is via an android phone. Desired setup is to:
Install pihole on the pi
Share the phone's connection with the pi via USB tethering
Share the pi's connection with my PCs via a wireless hotspot
I've succeeded with:
(1 and 2) together - enjoying pihole-filtered internet on the pi itself with tethered internet.
(2 and 3) together - running a hotspot from the pi that shares its tethered internet access with my PCs
But 1 and 3 have been interfering with one another. When pi-hole is enabled, my hotspot is failing to share internet.
Has anyone produced a guide for this use-case?
jfb
October 14, 2018, 5:17am
2
Why do you need to tether the Pi to the phone? Can your phone create a wireless personal hotspot? If it can, put the Pi on the network like you would with a router-sourced network.
NiloCK
October 14, 2018, 4:46pm
3
The pi has actually had substantial difficulty connecting to the phone's hotspot. It connects, but unreliably and randomly (as far as I can tell).
In any case, I don't see any clear path to enabling the pi-hole dns blocking for other devices (PCs) that share the same access point.
Mcat12
October 15, 2018, 2:11am
4
Most tethering situations don't allow clients to communicate with each other.
NiloCK
October 15, 2018, 3:46am
5
Yes. This is why I plan to use the USB tethering so that the pi has access, and so that the pi can then act as host / server to my PCs as clients. That way there isn't any need for client-client communication.
system
Closed
November 5, 2018, 3:46am
6
