I have a PC Engine APU2 appliance that was used for PFSense. I have moved on to a different gateway and was wondering if I can use it as my Pi-Hole?
I cannot find anything on the www. has anyone here tried this?
Thanks,
Gary
Thanks,
Gary
You might be the first to try it. If the device will run one of the supported versions of Linux, you may have success.
It will run Debian 9. I am a linux noob and am having difficulties learning how to get Debian installed with this wacky APU bios. I have also been thinking of making it into a honeypot using https://haas.nic.cz/
thanks for replying,
G
