Use non-default ports for admin panel
The issue I am facing:
I want to use a port other than port 80/443
Details about my system:
Pihole is installed to an Ubuntu 22.04 laptop
pihole Core version: 6.2.2
pihole FTL version 6.3.3
An other program (nexcloud) is occupying 0.0.0.0:443 and 0.0.0.0:80
Tried but didn’t work: put WEB_PORT=8080 and API_PORT=8080 to /etc/pihole/pihole-FTL.conf
I saw old solutions when lighttpd was used but as far as I know it is not being used anymore.
That is not the correct configuration file for Pi-hole V6. The configuration file for V6 is /etc/pihole/pihole.toml. This is the file that is changed when you make configuration changes on the web admin interface, and you can also edit the file manually.
Look for this section of the file (in this example the default ports have been modified):
  # Ports to be used by the webserver.
  # Comma-separated list of ports to listen on. It is possible to specify an IP address
  # to bind to. In this case, an IP address and a colon must be prepended to the port
  # number. For example, to bind to the loopback interface on port 80 (IPv4) and to all
  # interfaces port 8080 (IPv4), use "127.0.0.1:80,8080". "[::]:80" can be used to
  # listen to IPv6 connections to port 80. IPv6 addresses of network interfaces can be
  # specified as well, e.g. "[::1]:80" for the IPv6 loopback interface. "[::]:80" will
  # bind to port 80 IPv6 only.
  # In order to use port 80 for all interfaces, both IPv4 and IPv6, use either the
  # configuration "80,[::]:80" (create one socket for IPv4 and one for IPv6 only), or
  # "+80" (create one socket for both, IPv4 and IPv6). The '+' notation to use IPv4 and
  # IPv6 will only work if no network interface is specified. Depending on your
  # operating system version and IPv6 network environment, some configurations might not
  # work as expected, so you have to test to find the configuration most suitable for
  # your needs. In case "+80" does not work for your environment, you need to use
  # "80,[::]:80".
  # If the port is TLS/SSL, a letter 's' (secure) must be appended, for example,
  # "80,443s" will open port 80 and port 443, and connections on port 443 will be
  # encrypted. For non-encrypted ports, it is allowed to append letter 'r' (as in
  # redirect). Redirected ports will redirect all their traffic to the first configured
  # SSL port. For example, if webserver.port is "80r,443s", then all HTTP traffic coming
  # at port 80 will be redirected to HTTPS port 443.
  # When specifying 'o' (optional) behind a port, inability to use this port is not
  # considered an error. For instance, specifying "80o,8080o" will allow the webserver
  # to listen on either 80, 8080, both or even none of the two ports. This flag may be
  # combined with 'r' and 's' like "80or,443os,8080,4443s" (80 redirecting to SSL if
  # available, 443 encrypted if available, 8080 mandatory and unencrypted, 4443
  # mandatory and encrypted).
  # If this value is not set (empty string), the web server will not be started and,
  # hence, the API will not be available.
  # Allowed values are:
  #     A comma-separated list of <[ip_address:]port>
  port = "80,[::]:80" ### CHANGED, default = "80o,443os,[::]:80o,[::]:443os"
Thank you, this worked
