Use-application-dns.net found in adlists
Thanks. Just for documentation: My previous PR has been superseded by
https://github.com/pi-hole/FTL/pull/1148
where the behavior is now even configurable (on/off). This is a much better and easier to understand strategy than post-processing the gravity database.
There is some progress on this. Someone filed a patch, assigned himself and upgraded priority:
Unfortunately, the in the discussion around the patch 0.0.0.0 was jugeded as "I don't think it's particularly important to allow 0.0.0.0."
Fortunately, Pi-hole handles this well and does not depend on them fixing it :slight_smile:
The change has been reverted because some tests failed. One could have fixed the tests, but ...
I think they included it again. Maybe they fixed the tests...
