Expected to upgrade my OS to one in support of Pi Hole, but have found it now fails to run the DNS Service.
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HARDWARE = Raspberry Pi 3+
System fails to run after upgrade of Raspian to a supported version, the system then fails to run properly with an error within the ' Tools > Pi Hole diagnostics' of "FTL failed to start due to cannot create ICMPv6 socket: Address family not supported by protocol" and within the 'Settings' tab
"There was a problem applying your settings.
Debugging information:
PHP error (2): fsockopen(): unable to connect to 127.0.0.1:4711 (Connection refused) in /var/www/html/admin/scripts/pi-hole/php/FTL.php:44"
https://tricorder.pi-hole.net/apxlvObM
I have found some topics on this forum and elsewhere with similar instances and have looked at some of the suggestions, but without joy and a good number have been mothballed having gone stale.
As an FYI I have done an in-place upgrade of the OS and then subsequently tried pihole -up and pihole -r via sudo and these haven't resolved the issue.
Certainly far from a Linux power user, so although I am capable of following instruction and technically knowledgable, I know where I am weaker, so am keen to do whatever to understand what is going on.
NB. Bit confused that what I believe is a supported OS having updated, still shows as not.
Thanks, Chris
