Upgraded to bookworm, web interface does not work anymore + pihole -r reports Unsupported OS detected: Debian 12
pihole -r
[β] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[i] SELinux not detected
[β] Update local cache of available packages
[i] Existing PHP installation detected : PHP version 8.2.7
[β] Checking apt-get for upgraded packages... up to date!
[i] Checking for / installing Required dependencies for OS Check...
[β] Checking for grep
[β] Checking for dnsutils
[β] Unsupported OS detected: Debian 12
If you are seeing this message and you do have a supported OS, please contact support.
https://docs.pi-hole.net/main/prerequisites/#supported-operating-systems
If you wish to attempt to continue anyway, you can try one of the following commands to skip this check:
e.g: If you are seeing this message on a fresh install, you can run:
curl -sSL https://install.pi-hole.net | sudo PIHOLE_SKIP_OS_CHECK=true bash
If you are seeing this message after having run pihole -up:
sudo PIHOLE_SKIP_OS_CHECK=true pihole -r
(In this case, your previous run of pihole -up will have already updated the local repository)
It is possible that the installation will still fail at this stage due to an unsupported configuration.
If that is the case, you can feel free to ask the community on Discourse with the Community Help category:
https://discourse.pi-hole.net/c/bugs-problems-issues/community-help/
Your debug token is: https://tricorder.pi-hole.net/Hb6I47Ht/
upgrade bullseye to bookworm
tried sudo PIHOLE_SKIP_OS_CHECK=true pihole -r
did not help
pihole -a -t
PHP Fatal error: Uncaught Error: Undefined constant "SQLITE3_OPEN_READWRITE" in /var/www/html/admin/scripts/pi-hole/php/teleporter.php:22
Stack trace:
#0 {main}
thrown in /var/www/html/admin/scripts/pi-hole/php/teleporter.php on line 22
