Upgraded to 5, not blocking
Expect ads to be blocked:
-operating system Fedora 32, Plasma
-hardware]_ HP desktop amd processor
Dashboard is not showing any blocks. Tried some obvious ads and they are not blocked.
Unfortunately the debug results cannot be uploaded. Curl error.
The story
I upgraded a working Pihole. It showed errors migrating the existing lists but I found the lists in the dashboard anyway. This is probably not the issue.
I think the problem is with the group management, in particular the client list. It just shows "loading" forever. I get an error popup.
"DataTables warning: table id=clientsTable - Invalid JSON response. For more information about this error, please see 1. Warning: Invalid JSON response"
And from the browser console I get DevTools failed to load SourceMap: Could not parse content for http://192.168.1.2/admin/style/vendor/bootstrap/js/bootstrap-toggle.min.js.map: Unexpected token < in JSON at position 5
http://192.168.1.2/admin/style/vendor/bootstrap/js/bootstrap-toggle.min.js.map doesn't exist but http://192.168.1.2/admin/style/vendor/bootstrap/js/bootstrap-toggle.min.js does.
So now I did an uninstall and did a fresh install. Now when I go to group management -> clients it no longer hangs.
I did a bit of searching and reading and it seems my old lists are no longer valid. This is inconvenient but I read the suggestions for adding proper lists.
So back to work.
