Upgraded Container, no longer have blocked ads
Running pihole/pihole:latest on Pi3 via docker sha256:623d099087d50c273380002b221f7c5e6691fb603bafbea949bc1e72857d1ed0
Was an upgrade of a previous version of the container. Noticed that ads appear to be getting through, checked blacklist, ran a gravity upgrade, still nothing. Did some querying here and had a hard time getting through all of the posts where people had resolvers set correctly. I by-passed client configuration (to be sure) and checked resolving directly via dig:
$ dig @pi.hole taboola.com
; <<>> DiG 9.11.5-P4-5.1ubuntu2.1-Ubuntu <<>> @pi.hole taboola.com
; (1 server found)
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 22791
;; flags: qr rd ra; QUERY: 1, ANSWER: 4, AUTHORITY: 0, ADDITIONAL: 1
; EDNS: version: 0, flags:; udp: 1452
;taboola.com.			IN	A
taboola.com.		148	IN	A	151.101.193.181
taboola.com.		148	IN	A	151.101.1.181
taboola.com.		148	IN	A	151.101.129.181
taboola.com.		148	IN	A	151.101.65.181
;; Query time: 24 msec
;; SERVER: 10.10.0.30#53(10.10.0.30)
;; WHEN: Sun Apr 12 16:50:15 PDT 2020
;; MSG SIZE  rcvd: 148
Based on a comment in a different thread, I tried blowing away the FTL Database and restarting the container, but that doesn't appear to work.
Ad Blocking
No Blocking
https://tricorder.pi-hole.net/6nv6ksvkru
It appears you have no blocklists loaded. See in the red section "Domains on block list -2" This should be a positive integer - likely in the thousands or millions. Check Settings > Blocklists to see if you have any blocklists defined and if they are enabled.
Looks correctly configured:
Can you check Stopped blocking after upgrade [arm64/aarch64 raspbian] · Issue #587 · pi-hole/docker-pi-hole · GitHub and see if this is the same thing you are seeing?
Yep DanSchaper certainly seems the same. Looking at GH.
