Upgrade to v6 failed (stuck on "Building tree...")
pihole -up should update the system without any problems
the process get stuck on "Building tree..." for over 50 min. (usually takes no more than 15 min) then the connection dropped (I was connected via ssh)
so I went back to pihole v5 restoring a previous image of the sd card for now
I've read around the forum that many people have had their building tree process blocked, apparently running out of RAM (I have a Raspberry 3B+ with 1GB)
I have over 11M domains on adlist but never had any problems on v5
ok, maybe this is the solution...
https://github.com/pi-hole/pi-hole/pull/5977
