Upgrade to 5.1 fails for FTL portion of update.
Cannot update FTL to 5.1 running Mint 19.3, 5.0 installed/updated without issues:
[i] Checking for updates...
[i] Pi-hole Core: up to date
[i] Web Interface: up to date
[i] FTL: update available
[i] FTL out of date, it will be updated by the installer.
[✓] Root user check
    .ccccc:,.
     :cccclll:.      ..,,
      :ccccclll.   ;ooodc
       'ccll:;ll .oooodc
         .;cll.;;looo:.
[i] Existing PHP installation detected : PHP version 7.2.24-0ubuntu0.18.04.6
[i] Performing unattended setup, no whiptail dialogs will be displayed
[✓] Disk space check
[✓] Checking for dhcpcd5
[✓] Checking for git
[✓] Checking for iproute2
[✓] Checking for whiptail
[✓] Checking for dnsutils
cat: /etc/upstream-release: Is a directory
[✗] Unsupported OS detected
Redirecting...
  This check can be skipped by setting the environment variable PIHOLE_SKIP_OS_CHECK to true
  e.g: export PIHOLE_SKIP_OS_CHECK=true
  By setting this variable to true you acknowledge there may be issues with Pi-hole during or after the install
  If that is the case, you can feel free to ask the community on Discourse with the Community Help category:
  https://discourse.pi-hole.net/c/bugs-problems-issues/community-help/
wcyet19dne
Any help appreciated thanks!
You'll need to follow the directions provided, Mint is not a supported OS and we're making that information more visible now.
The solution is right there:
I am newbie to linux where do I set this ?
Gato
Right in the terminal
sudo PIHOLE_SKIP_OS_CHECK=true pihole -up
OK thanks all,
I guess I was overthinking it and was looking for a config file or something, this worked really appreciate it.
I really want to continue using Pi-Hole.
Gato
