Upgrade Pihole ftl broke
The issue I am facing:
updated pihole dns failed.
There was a problem applying your settings.
Debugging information:
PHP error (2): fsockopen(): unable to connect to 127.0.0.1:4711 (Connection refused) in /var/www/html/admin/scripts/pi-hole/php/FTL.php:47
Details about my system:
Running on a Unifi Could key ver 1
[Guide] Installing Pi-hole on Unifi Cloudkey v1
i tried to update it which borked my install
[✓] Your debug token is: https://tricorder.pi-hole.net/RMIK5XGL/
sudo service dnsmasq status
root@UniFi-CloudKey:~# sudo service dnsmasq status
Unit dnsmasq.service could not be found.
root@UniFi-CloudKey:~# sudo service pihole-FTL status
● pihole-FTL.service - Pi-hole FTL
   Loaded: loaded (/etc/systemd/system/pihole-FTL.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Sat 2023-01-21 23:52:57 PST; 12min ago
  Process: 23366 ExecStartPre=/opt/pihole/pihole-FTL-prestart.sh (code=exited, status=0/SUCCESS)
  Process: 23382 ExecStart=/usr/bin/pihole-FTL -f (code=exited, status=218/CAPABILITIES)
  Process: 23384 ExecStopPost=/opt/pihole/pihole-FTL-poststop.sh (code=exited, status=0/SUCCESS)
 Main PID: 23382 (code=exited, status=218/CAPABILITIES)
Jan 21 23:52:57 UniFi-CloudKey systemd[1]: Stopped Pi-hole FTL.
Jan 21 23:52:57 UniFi-CloudKey systemd[1]: pihole-FTL.service: Start request repeated too quickly.
Jan 21 23:52:57 UniFi-CloudKey systemd[1]: pihole-FTL.service: Failed with result 'exit-code'.
Jan 21 23:52:57 UniFi-CloudKey systemd[1]: Failed to start Pi-hole FTL.
Any ideas on how I might fix this?
I am at a loss here guys. Do i need to update debian os to a new version? I dont know how to get the dns server to run. Suggestions ? It worked great for a long time before the recent upgrade to new version
Can i install a older version before 5.20 or whatever? What would the command be with curl to download an older version
I really like the software, i am currently using truenas scale to run pi hole in a docker type deal, while my unifi cloud key gen 1 sits running pi hole with no dns server.
If I have do I guess i could buy a rasberry pi computer, but i dont know what version would be good, and the cloud key works so well, and it is poe powered
Please upload a fresh debug log and post the new token here. You old log auto-expired after 48 hours.
Active: failed (Result: exit-code) since Sun 2023-01-22 04:12:49 PST; 3 days ago
Process: 3049 ExecStartPre=/opt/pihole/pihole-FTL-prestart.sh (code=exited, status=0/SUCCESS)
Process: 3063 ExecStart=/usr/bin/pihole-FTL -f (code=exited, status=218/CAPABILITIES)
Process: 3065 ExecStopPost=/opt/pihole/pihole-FTL-poststop.sh (code=exited, status=0/SUCCESS)
Main PID: 3063 (code=exited, status=218/CAPABILITIES)
Jan 22 04:12:49 UniFi-CloudKey systemd[1]: pihole-FTL.service: Service RestartSec=5s expired, scheduling restart.
Jan 22 04:12:49 UniFi-CloudKey systemd[1]: pihole-FTL.service: Scheduled restart job, restart counter is at 5.
Jan 22 04:12:49 UniFi-CloudKey systemd[1]: Stopped Pi-hole FTL.
Jan 22 04:12:49 UniFi-CloudKey systemd[1]: pihole-FTL.service: Start request repeated too quickly.
Jan 22 04:12:49 UniFi-CloudKey systemd[1]: pihole-FTL.service: Failed with result 'exit-code'.
Jan 22 04:12:49 UniFi-CloudKey systemd[1]: Failed to start Pi-hole FTL.
  • The debug log can be uploaded to tricorder.pi-hole.net for sharing with developers only.
* Error message: curl: (22) The requested URL returned error: 500
  • A local copy of the debug log can be found at: /var/log/pihole/pihole_debug.log
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations.  This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected.  Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2023-01-25:16:41:14 debug log has been initialized.
[i] System has been running for 3 days, 17 hours, 34 minutes
[✓] Version: v5.15
[i] Remotes: origin     https://github.com/pi-hole/pi-hole.git (fetch)
             origin     https://github.com/pi-hole/pi-hole.git (push)
[i] Branch: master
[i] Commit: v5.15-0-g9048429
[✓] Version: v5.18.1
[i] Remotes: origin     https://github.com/pi-hole/AdminLTE.git (fetch)
             origin     https://github.com/pi-hole/AdminLTE.git (push)
[i] Branch: master
[i] Commit: v5.18.1-0-g30668d4
[✓] Version: v5.20.1
[i] Branch: master
[i] Commit: 47128aaf
[i] 1.4.53
[i] 7.3.31
[✓] Distro:  Debian
[✓] Version: 10
[✓] dig return code: 0
[i] dig response: "Raspbian=10,11 Ubuntu=20,22 Debian=10,11 Fedora=36,37 CentOS=8,9"
[✓] Distro and version supported
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: FirewallD
[i] Firewalld service inactive
*** [ DIAGNOSING ]: Processor
[✓] armv7l
*** [ DIAGNOSING ]: Disk usage
   Filesystem                     Size  Used Avail Use% Mounted on
   udev                            10M     0   10M   0% /dev
   tmpfs                          404M  424K  404M   1% /run
   /dev/disk/by-label/userdata    2.9G  1.2G  1.8G  41% /mnt/.rwfs
   /dev/disk/by-partlabel/rootfs  334M  334M     0 100% /mnt/.rofs
   aufs-root                      2.9G  1.2G  1.8G  41% /
   tmpfs                         1009M     0 1009M   0% /dev/shm
   tmpfs                          5.0M     0  5.0M   0% /run/lock
   tmpfs                         1009M     0 1009M   0% /sys/fs/cgroup
   tmpfs                         1009M   30M  980M   3% /tmp
   /dev/mmcblk0p8                  11G   41M   11G   1% /srv
   /dev/mmcblk1p1                 7.2G   62M  7.2G   1% /data
   tmpfs                          202M     0  202M   0% /run/user/0
*** [ DIAGNOSING ]: Network interfaces and addresses
   1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
       inet6 ::1/128 scope host
   2: eth0p: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000
       link/ether b6:fb:e4:2a:aa:a1 brd ff:ff:ff:ff:ff:ff
   3: gre0: <NOARP> mtu 1476 qdisc noop state DOWN group default
       link/gre 0.0.0.0 brd 0.0.0.0
   4: gretap0: <BROADCAST,MULTICAST> mtu 1476 qdisc noop state DOWN group default qlen 1000
       link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
   5: sit0: <NOARP> mtu 1480 qdisc noop state DOWN group default
       link/sit 0.0.0.0 brd 0.0.0.0
   6: ip6tnl0: <NOARP> mtu 1452 qdisc noop state DOWN group default
       link/tunnel6 :: brd ::
   7: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000
       link/ether b4:fb:e4:2a:aa:a1 brd ff:ff:ff:ff:ff:ff
       inet 192.168.5.3/24 brd 192.168.5.255 scope global dynamic eth0
          valid_lft 82609sec preferred_lft 82609sec
       inet6 fe80::b6fb:e4ff:fe2a:aaa1/64 scope link
*** [ DIAGNOSING ]: Network routing table
   default via 192.168.5.1 dev eth0 proto dhcp src 192.168.5.3 metric 1024
   192.168.5.0/24 dev eth0 proto kernel scope link src 192.168.5.3
   192.168.5.1 dev eth0 proto dhcp scope link src 192.168.5.3 metric 1024
    192.168.5.3/24
[i] Default IPv4 gateway(s):
     192.168.5.1
   * Pinging first gateway 192.168.5.1...
[✓] Gateway responded.
[i] Default IPv6 gateway(s):
    udp:192.168.5.3:68 is in use by systemd-network
    udp:0.0.0.0:5353 is in use by avahi-daemon
    udp:0.0.0.0:54274 is in use by avahi-daemon
    udp:*:5353 is in use by avahi-daemon
    udp:*:59005 is in use by avahi-daemon
    tcp:127.0.0.1:9090 is in use by ubnt-systemhub
    tcp:0.0.0.0:8080 is in use by lighttpd
    tcp:0.0.0.0:22 is in use by sshd
    tcp:127.0.0.1:25 is in use by exim4
    tcp:*:8080 is in use by lighttpd
    tcp:*:22 is in use by sshd
    tcp:[::1]:25 is in use by exim4
[✗] Failed to resolve comunicazioni.stanhome.it on lo (127.0.0.1)
[✓] No IPv4 address available on eth0p
[✗] Failed to resolve comunicazioni.stanhome.it on eth0 (192.168.5.3)
[✓] doubleclick.com is 142.250.69.206 via a remote, public DNS server (8.8.8.8)
[✗] Failed to resolve polska-dpd.17253.space on lo (::1)
[✓] No IPv6 address available on eth0p
[✗] Failed to resolve polska-dpd.17253.space on eth0 (fe80::b6fb:e4ff:fe2a:aaa1)
[✗] Failed to resolve doubleclick.com via a remote, public DNS server (2001:4860:4860::8888)
   Timeout: 10 seconds
   WARN: Could not sendto() in send_dhcp_discover() (/__w/FTL/FTL/src/dhcp-discover.c:233): Network is unreachable
   * Received 305 bytes from eth0:192.168.5.1
     Offered IP address: 192.168.5.3
     Server IP address: 192.168.5.1
     Relay-agent IP address: N/A
     BOOTP server: (empty)
     BOOTP file: (empty)
     DHCP options:
      Message type: DHCPOFFER (2)
      server-identifier: 192.168.5.1
      lease-time: 86400 ( 1d )
      renewal-time: 43200 ( 12h )
      rebinding-time: 75600 ( 21h )
      netmask: 255.255.255.0
      domain-name: "localdomain"
      broadcast: 192.168.5.255
      dns-server: 192.168.5.1
      router: 192.168.5.1
      --- end of options ---
   DHCP packets received on interface gre0: 0
   DHCP packets received on interface ip6tnl0: 0
   DHCP packets received on interface gretap0: 0
   DHCP packets received on interface sit0: 0
   DHCP packets received on interface eth0p: 0
[✓] lighttpd daemon is active
[✗] pihole-FTL daemon is failed
*** [ DIAGNOSING ]: Pi-hole-FTL full status
    PIHOLE_INTERFACE=eth0
    PIHOLE_DNS_1=1.1.1.1
    PIHOLE_DNS_2=1.0.0.1
    QUERY_LOGGING=true
    INSTALL_WEB_SERVER=true
    INSTALL_WEB_INTERFACE=true
    LIGHTTPD_ENABLED=true
    CACHE_SIZE=10000
    DNS_FQDN_REQUIRED=true
    DNS_BOGUS_PRIV=true
    DNSMASQ_LISTENING=local
    WEBUIBOXEDLAYOUT=boxed
    WEBTHEME=default-dark
*** [ DIAGNOSING ]: Dashboard headers
[✗] Web interface X-Header: X-Header does not match or could not be retrieved.
*** [ DIAGNOSING ]: Pi-hole FTL Query Database
-rw-rw-r-- 1 pihole pihole 0 Jan 22 00:04 /etc/pihole/pihole-FTL.db
*** [ DIAGNOSING ]: Gravity Database
-rw-rw-r-- 1 pihole pihole 12M Jan 22 04:12 /etc/pihole/gravity.db
*** [ DIAGNOSING ]: Info table
   property              value
   version               15
   updated               1674389536
   gravity_count         171069
   Last gravity run finished at: Sun Jan 22 04:12:16 PST 2023
   ----- First 10 Gravity Domains -----
   localhost.localdomain
   eu1.clevertap-prod.com
   wizhumpgyros.com
   coccyxwickimp.com
   webmail-who-int.000webhostapp.com
   010sec.com
   01mspmd5yalky8.com
   0byv9mgbn0.com
   ns6.0pendns.org
   dns.0pengl.com
*** [ DIAGNOSING ]: Groups
   id    enabled  name                                                date_added           date_modified        description
   0           1  Default                                             2023-01-21 23:28:12  2023-01-21 23:28:12  The default group
*** [ DIAGNOSING ]: Clients
*** [ DIAGNOSING ]: Adlists
   id     enabled  group_ids     address        date_added           date_modified        comment
   1            1  0             https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts                                      2023-01-21 23:28:12  2023-01-21 23:28:12  Migrated from /etc/pihole/adlists.list
-rw-r--r-- 1 root root 0 Jan 21 23:11 /etc/pihole/custom.list
-rw-r--r-- 1 root root 65 Jan 22 04:12 /etc/pihole/local.list
-rw-r--r-- 1 root root 241 Jan 21 23:11 /etc/pihole/logrotate
   /var/log/pihole/pihole.log {
        su root root
        daily
        copytruncate
        rotate 5
        compress
        delaycompress
        notifempty
        nomail
   /var/log/pihole/FTL.log {
        su root root
        weekly
        copytruncate
        rotate 3
        compress
        delaycompress
        notifempty
        nomail
-rw-rw-r-- 1 pihole root 127 Jan 21 23:52 /etc/pihole/pihole-FTL.conf
   PRIVACYLEVEL=0
-rw-r--r-- 1 root root 324 Jan 24 18:46 /etc/pihole/versions
   CORE_VERSION=v5.15
   CORE_BRANCH=master
   CORE_HASH=9048429b
   GITHUB_CORE_VERSION=v5.15.2
   GITHUB_CORE_HASH=262ffe4
   WEB_VERSION=v5.18.1
   WEB_BRANCH=master
   WEB_HASH=30668d4d
   GITHUB_WEB_VERSION=v5.18.2
   GITHUB_WEB_HASH=c3c230a
   FTL_VERSION=v5.20.1
   FTL_BRANCH=master
   FTL_HASH=47128aaf
   GITHUB_FTL_VERSION=v5.20.1
   GITHUB_FTL_HASH=47128aa
-rw-r--r-- 1 root root 1.4K Jan 21 23:52 /etc/dnsmasq.d/01-pihole.conf
   localise-queries
   no-resolv
   log-queries
   log-facility=/var/log/pihole/pihole.log
   log-async
   cache-size=10000
   server=1.1.1.1
   server=1.0.0.1
   domain-needed
   expand-hosts
   bogus-priv
   local-service
-rw-r--r-- 1 root root 2.2K Jan 21 23:52 /etc/dnsmasq.d/06-rfc6761.conf
   server=/test/
   server=/localhost/
   server=/invalid/
   server=/bind/
   server=/onion/
-rw-r--r-- 1 root root 2.0K Jan 21 23:43 /etc/lighttpd/lighttpd.conf
   server.modules = (
        "mod_indexfile",
        "mod_access",
        "mod_alias",
        "mod_redirect",
   server.pid-file             = "/var/run/lighttpd.pid"
   server.port                 = 8080
   server.http-parseopts = (
     "header-strict"           => "enable",# default
     "host-strict"             => "enable",# default
     "host-normalize"          => "enable",# default
     "url-normalize-unreserved"=> "enable",# recommended highly
     "url-normalize-required"  => "enable",# recommended
     "url-ctrls-reject"        => "enable",# recommended
     "url-path-2f-decode"      => "enable",# recommended highly (unless breaks app)
     "url-path-dotseg-remove"  => "enable",# recommended highly (unless breaks app)
   index-file.names            = ( "index.php", "index.html" )
   url.access-deny             = ( "~", ".inc" )
   compress.cache-dir          = "/var/cache/lighttpd/compress/"
   compress.filetype           = ( "application/javascript", "text/css", "text/html", "text/plain" )
   include_shell "/usr/share/lighttpd/create-mime.conf.pl"
   include "/etc/lighttpd/conf-enabled/*.conf"
   server.modules += (
        "mod_compress",
        "mod_dirlisting",
        "mod_staticfile",
-rw-r--r-- 1 root root 1.7K Jan 21 23:52 /etc/cron.d/pihole
   12 4   * * 7   root    PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updateGravity >/var/log/pihole/pihole_updateGravity.log || cat /var/log/pihole/pihole_updateGravity.log
   00 00   * * *   root    PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole flush once quiet
   @reboot root /usr/sbin/logrotate --state /var/lib/logrotate/pihole /etc/pihole/logrotate
   46 18  * * *   root    PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker
   @reboot root    PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker reboot
-rw-r--r-- 1 www-data www-data 4.8K Jan 25 16:39 /var/log/lighttpd/error-pihole.log
   -----head of error-pihole.log------
   2023-01-22 00:00:00: (server.c.1759) logfiles cycled UID = 0 PID = 25326
   2023-01-22 00:14:02: (gw_backend.c.476) unlink /tmp/pihole-php-fastcgi.socket-0 after connect failed: Connection refused
   2023-01-22 00:14:03: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
   2023-01-22 00:14:08: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
   2023-01-22 10:00:02: (gw_backend.c.476) unlink /tmp/pihole-php-fastcgi.socket-0 after connect failed: Connection refused
   2023-01-22 10:00:02: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
   2023-01-22 10:00:07: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
   2023-01-22 10:04:05: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
   2023-01-22 10:04:10: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
   2023-01-22 10:04:34: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
   2023-01-22 10:04:38: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
   2023-01-22 10:04:49: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
   2023-01-22 10:04:53: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
   2023-01-22 10:04:59: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
   2023-01-22 10:05:03: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
   2023-01-22 10:05:06: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
   2023-01-22 10:05:10: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
   2023-01-22 10:05:31: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
   2023-01-22 10:05:37: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
   2023-01-22 18:16:56: (gw_backend.c.476) unlink /tmp/pihole-php-fastcgi.socket-0 after connect failed: Connection refused
   2023-01-22 18:16:57: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
   2023-01-22 18:17:02: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
   2023-01-25 06:08:58: (gw_backend.c.476) unlink /tmp/pihole-php-fastcgi.socket-0 after connect failed: Connection refused
   2023-01-25 06:08:59: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
   2023-01-25 06:09:04: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
   -----tail of error-pihole.log------
   2023-01-25 16:38:55: (gw_backend.c.476) unlink /tmp/pihole-php-fastcgi.socket-0 after connect failed: Connection refused
   2023-01-25 16:38:57: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
   2023-01-25 16:39:02: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
*** [ DIAGNOSING ]: contents of /var/log/pihole
-rw-r--r-- 1 pihole pihole 0 Jan 21 23:15 /var/log/pihole/FTL.log
   -----head of FTL.log------
   -----tail of FTL.log------
*** [ DIAGNOSING ]: contents of /dev/shm
-rw-r--r-- 1 root root 24 Jan 21 23:52 /etc/dnsmasq.conf
   conf-dir=/etc/dnsmasq.d
lrwxrwxrwx 1 root root 32 Jan 21 23:11 /etc/resolv.conf -> /run/systemd/resolve/resolv.conf
   nameserver 192.168.5.1
*** [ DIAGNOSING ]: Pi-hole diagnosis messages
Error: in prepare, no such table: message
*** [ DIAGNOSING ]: Locale
    LANG=C
-rw-r----- 1 pihole pihole 0 Jan 21 23:15 /var/log/pihole/pihole.log
   -----head of pihole.log------
   -----tail of pihole.log------
[✓] ** FINISHED DEBUGGING! **
   * A local copy of the debug log can be found at: /var/log/pihole/pihole_debug.log
root@UniFi-CloudKey:~# ^C
Does it matter if I have 2 pi holes running? I have this one that has the problem with DNS 192.168.5.3
And then I have the pihole running on my truenas scale server at 192.168.5.100/9089
I can shut the server one down if needed.
[✓] Your debug token is: https://tricorder.pi-hole.net/ePWswlxy/
[i] Logs are deleted 48 hours after upload.
Sorry I turned off the server pi hole. reset dns from router back to stock and then re tried to get a code and it worked this time ill leave it like for for a few days.
And sorry if I am not doing this correctly, I only dabble in linux to make my truenas work and I know dos a bit etc but, I am more of a script kiddy finding ways to use hard ware in ways it wasn't designed.
The Error message: curl: (22) The requested URL returned error: 500 message wasn't your fault. Our server had an issue.
Oh, well the dns end wont boot.
Error
FTL Information
The FTL service is offline!
off the website.
Please check your route "sudo route -v" if you don't have a default route
that got wiped on an update somehow. It should be something like what is below:
Kernel IP routing table
default fire 0.0.0.0 UG 0 0 0 ens160
192.168.xxx.x 0.0.0.0 255.255.255.0 U 0 0 0 ens160
