As the contents of /boot are moved to /boot/firmware in Bookworm, one should first create /boot/firmware:
sudo mkdir /boot/firmware
change the new directory's permissions
sudo chmod 755 /boot/firmware
ls -la /boot/firmware/ should return the following directory permissions:
drwxr-xr-x 4 root root 6144 Jan 1 1970 .
drwxr-xr-x 3 root root 4096 Feb 21 03:31 ..
and then move everything in /boot to /boot/firmware/
sudo mv /boot/* /boot/firmware/
DO NOT REBOOT BEFORE COMPLETING YOUR UPGRADE
To ensure your current install is up to date, run :
sudo apt update && sudo apt full-upgrade -y && sudo apt autoremove -y && sudo apt autoclean -y
Then change the sources. The sources will depend on whether you're using the 32-bit or 64-bit version of Bullseye.
32-bit (armhf) sources:
cat /etc/apt/sources.list
deb [ arch=armhf ] http://raspbian.raspberrypi.com/raspbian/ bookworm main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://raspbian.raspberrypi.com/raspbian/ bookworm main contrib non-free rp
and
cat /etc/apt/sources.list.d/raspi.list
deb http://archive.raspberrypi.com/debian/ bookworm main
#deb-src http://archive.raspberrypi.com/debian/ bookworm main
or
64-bit (arm64) sources:
deb http://deb.debian.org/debian bookworm main contrib non-free non-free-firmware
deb http://deb.debian.org/debian-security/ bookworm-security main contrib non-free non-free-firmware
deb http://deb.debian.org/debian bookworm-updates main contrib non-free non-free-firmware
# Uncomment deb-src lines below then 'apt-get update' to enable 'apt-get source'
#deb-src http://deb.debian.org/debian bookworm main contrib non-free non-free-firmware
#deb-src http://deb.debian.org/debian-security/ bookworm-security main contrib non-free non-free-firmware
#deb-src http://deb.debian.org/debian bookworm-updates main contrib non-free non-free-firmware
and
Now run:
sudo apt update && sudo apt full-upgrade -y && sudo apt autoremove -y && sudo apt autoclean -y && dpkg --configure -a
The run sudo apt update
You will get the warning:
W: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg)
To fix, run apt-key list | grep -A4 "trusted.gpg$"
Replace <hex_key> with the last eight hexadecimal digits of the public key from the last command, with the space removed (<hex_key> example: 6A7D8E9F)
apt-key export <hex_key>| gpg --dearmor -o /tmp/raspi.gpg
apt-key del <hex_key>
mv /tmp/raspi.gpg /etc/apt/trusted.gpg.d/
Finally, run sudo apt update && sudo apt full-upgrade -y && sudo apt autoremove -y && sudo apt autoclean -y && sudo reboot
Your system should reboot and be running up to date Bookworm.
