Upgrade with no errors.
Using curl for transmission. There was an error uploading your debug log. Please contact pi-hole team.
Ever since version Ver.4.0 was released, I have trouble updating every new versions there after. Below is a partial list of what pihole is doing during the upgrade. There is one error as you can see. My system is using dnsmasq and pihole has do away with it after version 4.0??
[i] Installing blocking page...
[✓] Creating directory for blocking page, and copying files
[✗] Backing up index.lighttpd.html
[✓] Installing sudoer file
[✓] Installing latest Cron script
[✓] Installing latest logrotate script
[i] Backing up /etc/dnsmasq.conf to /etc/dnsmasq.conf.old
[✓] man pages installed and database updated
[i] Testing if systemd-resolved is enabled
[i] Systemd-resolved is not enabled
[✓] Restarting lighttpd service...
[✓] Enabling lighttpd service to start on reboot...
[i] Restarting services...
[✓] Enabling pihole-FTL service to start on reboot...
[✓] Restarting pihole-FTL service...
[✓] Deleting existing list cache
[✗] DNS service is not running
[✓] Starting DNS service
[✗] DNS resolution is not available
*What I have tried but failed to get pihole up and running:
Stopping dnsmasq and restarting pihole-FTL. Rebooting the pi.
*What I have tried with success after every failed upgrade attempt to get pihole up and running:
Change line: su -s /bin/sh -c "/usr/bin/pihole-FTL" "$FTLUSER" -> /usr/bin/pihole-FTL in '/etc/init.d/pihole-FTL'
sudo systemctl daemon-reload
sudo service pihole-FTL restart
I would like to fix this, but do not know where to look. If you need any other info, please let me know. Thanks you.
