[✓] Your debug token is: ef2gpppbg2
root@pihole:~# sudo pihole -up
[i] Checking for updates...
[i] Pi-hole Core: up to date
[i] FTL: update available
[i] FTL out of date
[i] FTL Checks...
[i] Downloading and Installing FTL...curl: (22) The requested URL returned error: 404 Not Found
Error: URL https://github.com/pi-hole/FTL/releases/download/v4.1.2/ not found
Please try the following steps
sudo nano /etc/resolv.conf
edit 127.0.0.1
to 9.9.9.9
or your preferred third party DNS service
save
Re-run pihole -up
i put
nameserver 9.9.9.9
instead of the defautl one but no luck. still same error
by the way i got 404 in my browser if i try to reach: https://github.com/pi-hole/FTL/releases/download/v4.1.2/
what OS is this on? the FTL download should directly grab one of the packages based on your architechture
uname -a
Linux pihole 4.4.127-mainline-rev1 #1 SMP Sun Apr 8 10:33:17 UTC 2018 armv7l armv7l armv7l GNU/Linux
still same trouble...
really strange.
sudo pihole -up
[i] FTL out of date
[i] FTL Checks...
What versions are you all currently on? pihole -v
Pi-hole version is v4.1.1 (Latest: v4.1.1)
AdminLTE version is v4.1.1 (Latest: v4.1.1)
FTL version is v3.0 (Latest: v4.1.2)
Mcat12
January 16, 2019, 4:31am
12
Try manually installing the new FTL version:
sudo service pihole-FTL stop
sudo wget https://ftl.pi-hole.net/v4.1.2/pihole-FTL-arm-linux-gnueabihf -O /usr/bin/pihole-FTL
sudo service pihole-FTL start
thanks.
it worked
root@pihole:~# sudo service pihole-FTL stop
root@pihole:~# sudo wget https://ftl.pi-hole.net/v4.1.2/pihole-FTL-arm-linux-gnueabihf -O /usr/bin/pihole-FTL
--2019-01-16 16:26:12-- https://ftl.pi-hole.net/v4.1.2/pihole-FTL-arm-linux-gnueabihf
Resolving ftl.pi-hole.net (ftl.pi-hole.net)... 139.59.170.52
Connecting to ftl.pi-hole.net (ftl.pi-hole.net)|139.59.170.52|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 3407856 (3.2M) [application/octet-stream]
Saving to: ‘/usr/bin/pihole-FTL’
/usr/bin/pihole-FTL 100%[===================>] 3.25M 6.70MB/s in 0.5s
2019-01-16 16:26:12 (6.70 MB/s) - ‘/usr/bin/pihole-FTL’ saved [3407856/3407856]
root@pihole:~# sudo service pihole-FTL start
root@pihole:~# pihole -v
FTL version is v4.1.2 (Latest: v4.1.2)
[i] FTL: up to date
[i] Web Interface: up to date
[✓] Everything is up to date!
Unfortunately after few minutes FTL stopped
Status
Active FTL offline
Load: 0.1 0.06 0.01
Memory usage: 4.5 %
trying rebooting entire server :-/
no luck
FTL down.
dns seems working but dashboard not.
how can i fix ?
[✓] Your debug token is: kcfvfdcg7z
Mcat12
January 17, 2019, 3:37am
16
You have dnsmasq running and taking up port 53. FTLDNS embeds its own version of dnsmasq, so you can stop and remove the other dnsmasq.
please any link or tutorial about this change ?
i would like to get everything working also after a reboot of course..
done
root@pihole:~# sudo systemctl stop dnsmasq
root@pihole:~# sudo systemctl disable dnsmasq
but i'm unsure about what will happen at next reboot...
dashboard now works
devnull
January 17, 2019, 10:01am
19
It‘s announced here: Pi-hole v4.0 Released With FTLDNS, Improved Blocking Modes, Regex, Docker, and More – Pi-hole
The long awaited version v4.0 of Pi-hole's FTL daemon is available! It ships with a built-in DNS server (based on a private fork of dnsmasq
) to provide you with the best performance. Due to the inclusion of the DNS server, you will see the daemon also being referred to as FTL DNS .
Source: Release Pi-hole FTL v4.0 · pi-hole/FTL · GitHub
Ok has been announced but what's not so good is that the upgrade does not worked.
At least for me of course. ( from 3.1 )
best regards
system
Closed
February 7, 2019, 1:23pm
21
