Running pihole -up on pihole 5.0 should upgrade pi-hole to 5.1.1
OS: Raspbian (Raspberry Pi OS) with Debian Buster
Hardware: Pi Zero Wireless
root@sdc-pi:/home/pi# pihole -up
[i] Checking for updates...
[i] Pi-hole Core: update available
error: cannot update the ref 'refs/remotes/origin/master': unable to append to '.git/logs/refs/remotes/origin/master': Structure needs cleaning
error: cannot update the ref 'refs/tags/v5.1.1': unable to append to '.git/logs/refs/tags/v5.1.1': Structure needs cleaning
fatal: log for refs/heads/master is emptyError: Local revision could not be obtained, please contact Pi-hole Support
Additional debugging output:
On branch master
Your branch is up to date with 'origin/master'.nothing to commit, working tree clean
https://tricorder.pi-hole.net/6tbkh7rs2o
I tried a similar post requiring dnsmasq (for some reason it was not on my Pi) and change some values to be a different DNS but that didn't work still. it updated some interfaces to 5.1.1 but not all.
