Updated Ubuntu Server 20.04 which seems to have broke Pihole. It was running just fine yesterday before the updates (was on 20.04 before the package updates as well). Using nslookup and pointing it to the server, nothing resolves, even things that should resolved (e.g. www.google.com). Appreciate any help.
[✗] No IPv4 address(es) found on the em1 interface.
[✗] No IPv6 address(es) found on the em1 interface.
* Pinging 192.168.1.1...
BLOCKING_ENABLED=true
PIHOLE_INTERFACE=em1
IPV4_ADDRESS=192.168.1.123/24
From a client that you believe should be connected to the Pi-Hole for DNS, from the command prompt or terminal on that client (and not via ssh or Putty to the Pi), what is the output of
C:>nslookup rock-media
DNS request timed out.
timeout was 2 seconds.
Server: UnKnown
Address: 192.168.1.123
C:>nslookup rock-media 192.168.1.123
Server: UnKnown
C:>nslookup pi.hole
Server: UnKnown
C:>nslookup pi.hole 192.168.1.123
Server: UnKnown
C:>ping 192.168.1.123
Pinging 192.168.1.123 with 32 bytes of data:
Reply from 192.168.1.123: bytes=32 time=2ms TTL=64
Reply from 192.168.1.123: bytes=32 time=1ms TTL=64
No firewall rules on router nor any iptables rules on my server
Current connections as per my ASUS router... (these are Google devices hardcoded to use Google DNS all other devices fall back to the router as the DNS server should the pihole be down)
udp 192.168.1.242:35660 8.8.8.8:53 ASSURED
udp 192.168.1.147:54198 8.8.8.8:53 ASSURED
udp 192.168.1.147:32969 8.8.8.8:53 ASSURED
udp 192.168.1.102:51983 8.8.8.8:53 ASSURED
udp 192.168.1.64:45384 8.8.8.8:53 ASSURED
udp 192.168.1.147:40166 8.8.8.8:53 ASSURED
udp 192.168.1.102:35194 8.8.8.8:53 ASSURED
udp 192.168.1.147:49322 8.8.8.8:53 ASSURED
udp 192.168.1.64:54050 8.8.8.8:53 ASSURED
udp 192.168.1.242:50255 8.8.8.8:53 ASSURED
udp 192.168.1.64:50624 8.8.8.8:53 ASSURED
udp 192.168.1.242:47579 8.8.8.8:53 ASSURED
udp 192.168.1.102:45623 8.8.8.8:53 ASSURED
PCAP ran on my server hosting pihole
rock@rock-media:~$ sudo tcpdump -n -t -r ~/dns.pcap port 53
reading from file /home/rock/dns.pcap, link-type EN10MB (Ethernet)
IP 192.168.1.32.35695 > 192.168.1.123.53: 51120+ A? scribe.logs.roku.com. (38)
IP 192.168.1.32.44514 > 192.168.1.123.53: 47508+ A? www.googleadservices.com. (42)
IP 192.168.1.32.36415 > 192.168.1.123.53: 38845+ A? r6---sn-qxoedn7d.googlevideo.com. (50)
IP 192.168.1.200.40611 > 192.168.1.123.53: 24007+ A? checkipv6.quickconnect.to. (43)
IP 192.168.1.200.40611 > 192.168.1.123.53: 35698+ AAAA? checkipv6.quickconnect.to. (43)
IP 192.168.1.200.49027 > 192.168.1.123.53: 9450+ A? checkip.dyndns.org. (36)
IP 192.168.1.200.54395 > 192.168.1.123.53: 57993+ AAAA? checkipv6.quickconnect.to. (43)
IP 192.168.1.200.54395 > 192.168.1.123.53: 35047+ A? checkipv6.quickconnect.to. (43)
IP 192.168.1.32.35207 > 192.168.1.123.53: 38597+ A? r4---sn-q4flrnez.googlevideo.com. (50)
IP 192.168.1.32.57898 > 192.168.1.123.53: 32644+ A? scribe.logs.roku.com. (38)
IP 192.168.1.31.51308 > 192.168.1.123.53: 25948+ A? 6c50b6bb6ac861983c454ea1bef9b60b.clo.footprintdns.com. (71)
IP 192.168.1.13.36462 > 192.168.1.123.53: 28305+ A? connectivitycheck.gstatic.com. (47)
IP 192.168.1.13.36462 > 192.168.1.123.53: 25585+ AAAA? connectivitycheck.gstatic.com. (47)
IP 192.168.1.32.36988 > 192.168.1.123.53: 31639+ A? scribe.logs.roku.com. (38)
IP 192.168.1.31.51312 > 192.168.1.123.53: 1+ PTR? 123.1.168.192.in-addr.arpa. (44)
IP 192.168.1.13.35432 > 192.168.1.123.53: 64031+ A? connectivitycheck.gstatic.com. (47)
IP 192.168.1.13.35432 > 192.168.1.123.53: 55645+ AAAA? connectivitycheck.gstatic.com. (47)
IP 192.168.1.31.52184 > 192.168.1.123.53: 47806+ A? google.com. (28)
IP 192.168.1.200.58202 > 192.168.1.123.53: 23464+ AAAA? checkipv6.synology.com. (40)
IP 192.168.1.31.60769 > 192.168.1.123.53: 49700+ A? clients6.google.com. (37)
IP 192.168.1.200.58524 > 192.168.1.123.53: 44075+ A? checkipv6.quickconnect.to. (43)
IP 192.168.1.200.58524 > 192.168.1.123.53: 52174+ AAAA? checkipv6.quickconnect.to. (43)
IP 192.168.1.32.59093 > 192.168.1.123.53: 29986+ A? scribe.logs.roku.com. (38)
IP 192.168.1.31.60771 > 192.168.1.123.53: 2+ A? www.google.com. (32)
IP 192.168.1.31.60772 > 192.168.1.123.53: 3+ AAAA? www.google.com. (32)
IP 192.168.1.31.63319 > 192.168.1.123.53: 53444+ A? router.asus.com. (33)
IP 192.168.1.31.63320 > 192.168.1.123.53: 4+ A? www.google.com. (32)
IP 192.168.1.32.34128 > 192.168.1.123.53: 40225+ A? scribe.logs.roku.com. (38)
IP 192.168.1.32.48250 > 192.168.1.123.53: 15491+ A? scribe.logs.roku.com. (38)
IP 192.168.1.31.63321 > 192.168.1.123.53: 5+ AAAA? www.google.com. (32)
IP 192.168.1.31.55265 > 192.168.1.123.53: 47090+ A? graph.facebook.com. (36)
So I may have found the issue. Looks like one of the updates cause my LAN interface to be renamed to eth0. I made the change in one of the pihole config files, but it didn't fix it. I then backed up the configuration via teleporter, reinstalled pihole, and then restored my block and whitelists. Pihole is now working again.
