instead of lighttpd
[Updated from stretch to bullseye as stretch now not supported]
[pihole has stopped blocking ads and the dash does appear, but none of the stats are working after update]
[https://tricorder.pi-hole.net/yBuy338E/]
Unfortunately after updating to Bullseye from Stretch, Pihole has stopped working, which was fine before the update. I have uploaded the debug log which might indicate the isssue could be to do with 'No IPv4 address(es) found on the eth0 interface'.
I am not knowledgeable at all on the subject, so hopefully someone might be able to help with the issue.
Thanks
