I ran pihole -up on my pi4 which also hosts piVPN (which is still running fine). Now the web interface of pinhole is no longer reachable with http://ip_adress/admin/index.php
web interface access now works with https and not with http anymore.
[✓] tcp:[::]:8080 is in use by pihole-FTL
For whatever reason, it was unable to bind to port 80 on startup (some other service using this port, perhaps?)
You can still access the web interface with plain http - either using port 8080 (http://your.ip.address:8080/admin / http://pi.hole:8080/admin) or you can change the port that pihole-FTL has bound to in the config file /etc/pihole/pihole.toml
