OK, so when recreating the container, it should look more like this, with the default variables removed, otherwise youare overriding any that may have changed in the image.
"CapAdd" : [],
"CapDrop" : [],
"cmd" : "",
"cpu_priority" : 50,
"enable_publish_all_ports" : false,
"enable_restart_policy" : true,
"enable_service_portal" : null,
"enabled" : true,
"entrypoint_default" : "/s6-init",
"env_variables" : [
"key" : "FTLCONF_REPLY_ADDR4",
"value" : "XXX"
"key" : "DNSMASQ_LISTENING",
"value" : "local"
"key" : "WEB_PORT",
"value" : "XXX"
"key" : "WEBPASSWORD",
"value" : "XXX"
"exporting" : false,
"id" : "XXX",
"image" : "pihole/pihole:latest",
"is_ddsm" : false,
"is_package" : false,
"links" : [],
"memory_limit" : 0,
"name" : "Pi-Hole",
"network" : [
"driver" : "host",
"name" : "host"
"network_mode" : "host",
"port_bindings" : [],
"privileged" : false,
"shortcut" : {
"enable_shortcut" : false,
"enable_status_page" : false,
"enable_web_page" : false,
"web_page_url" : ""
"use_host_network" : true,
"volume_bindings" : [
"host_volume_file" : "/docker/pihole/pihole",
"mount_point" : "/etc/pihole",
"type" : "rw"
"host_volume_file" : "/docker/pihole/dnsmasq.d",
"mount_point" : "/etc/dnsmasq.d/",
"type" : "rw"
You should also replace the ServerIP
variable with FTLCONF_REPLY_ADDR4
(I have done this above) as it is now deprecated: GitHub - pi-hole/docker-pi-hole: Pi-hole in a docker container
