Hi everyone
Hope everyone is staying well and safe.
Trying to update pi-hole on docker on Mac OS.
I understand I shouldn't run pihole -up or pihole -r
Ive read this:
There is one thing im not sure on-
" * If you care about your data (logs/customisations), make sure you have it volume-mapped or it will be deleted in this step."
How do I do this? I would like to keep all logs/customisations and lists etc. Is backing up my lists a separate action to logs/customisations?
I can follow the instructions but im not sure how I should volume map the data,
Apologies if I sound stupid but this I've only very recently dived into docker for the first time when it came to running pi-hole. I am not experienced with code or this type of stuff but am trying to learn.
Hope someone can advise as I think this is a simple one.
Many thanks!
