jf62
March 21, 2024, 10:02pm
1
If I try to do a manual update of gravity db then the website show for a second the update button and then go to System settings
jf62
March 22, 2024, 3:03pm
2
Are I'm the only one with this error which came up after last update of Web Interface to Version vDev (development-v6, 7d51f402) ?
Having the same version on two Raspberry Pi's, manual update works fine here.
Core vDev (development-v6, 206cf9c4) FTL vDev (development-v6, 0d2fcd09)Web interface vDev (development-v6, 7d51f402)
No one else reported similar problems.
This seems to be an issue in your system.
We need more information.
jf62
March 22, 2024, 5:13pm
5
jf62
March 22, 2024, 8:35pm
7
Since I have a Proxmox system with backups, I went back to the version
FTL vDev (development-v6, c835795a)
Web interface vDev (development-v6, 71d396e3)
and the Bug isn't there
jf62
March 23, 2024, 1:57pm
8
I tested further and can reproduce the bug.
If Settings are set to BASIC the error occures, If I change to EXPERT all work as expected
OK. I can reproduce the issue.
We need to investigate, but apparently this is a side effect of a change made when we introduced the new Settings Level toggle selector.
DL6ER
March 23, 2024, 6:50pm
10
Thanks for the report, the proposed bug fix is here awaiting review:
pi-hole:development-v6
← pi-hole:fix/redirect_settings
opened 06:49PM - 23 Mar 24 UTC
# What does this implement/fix?
We should not try to apply settings levels (i… ncl. all the consequences such as ill-fated redirects) when we have already detected that there are no expert-settings elements on this page.
**Related issue or feature (if applicable):** https://github.com/pi-hole/web/issues/2992
**Pull request in [docs](https://github.com/pi-hole/docs) with documentation (if applicable):** N/A
1. I have read and understood the [contributors guide](https://docs.pi-hole.net/guides/github/contributing/), as well as this entire template. I understand which branch to base my commits and Pull Requests against.
2. I have commented my proposed changes within the code.
3. I am willing to help maintain this change if there are issues with it later.
4. It is compatible with the [EUPL 1.2 license](https://opensource.org/licenses/EUPL-1.1)
5. I have squashed any insignificant commits. ([`git rebase`](http://gitready.com/advanced/2009/02/10/squashing-commits-with-rebase.html))
## Checklist:
- [x] The code change is tested and works locally.
- [x] I based my code and PRs against the repositories `developmental` branch.
- [x] I [signed off](https://docs.pi-hole.net/guides/github/how-to-signoff/) all commits. Pi-hole enforces the [DCO](https://docs.pi-hole.net/guides/github/dco/) for all contributions
- [x] I [signed](https://docs.github.com/en/authentication/managing-commit-signature-verification/signing-commits) all my commits. Pi-hole requires signatures to verify authorship
- [x] I have read the above and my PR is ready for review.
