Hello! Just installed a new Pi-Hole Server in CentOS 7.
The issue I am facing:
Gravity List Cannot be updated
Details about my system:
When run pihole -g get error as below:
[✗] Pulling blocklist source list into range
[i] No source list found, or it is empty
[i] Building tree...
[✗] Unable to build gravity tree in /etc/pihole/gravity_temp.db
Error: no such table: main.gravity
when try pihole -g -r
[✗] Unable to fill table adlist in database /etc/pihole/gravity.db
Error: /tmp/tmp.VMr0BjNnzB.gravity line 1: expected 7 columns of data but found 6
Tried to delete gravity.db and gravity_temp.db and situation is the same!
Nothing, since installation I got this error! Error: /tmp/tmp.[tablename].gravity line 1: expected 7 columns of data but found 6
[root@pihole ~]# pihole -g -f
[✓] Deleting existing list cache
[i] Number of gravity domains: 0 (0 unique domains)
[i] Number of exact blacklisted domains: 0
[i] Number of regex blacklist filters: 0
[i] Number of exact whitelisted domains: 0
[i] Number of regex whitelist filters: 0
[✓] Flushing DNS cache
[✓] Cleaning up stray matter
You have no adlists shown. Use this FAQ to restore the default lists and rebuild gravity. If this produces errors please reply with the output and a new debug token.
Edit: also check your firewalld settings against our documentation:
Your debug log shows the following:
*** [ DIAGNOSING ]: FirewallD
[i] Firewalld service active
[✗] Allow Service: http (https://docs.pi-hole.net/main/prerequisites/#firewalld)
[✗] Allow Service: dns (https://docs.pi-hole.net/main/prerequisites/#firewalld)
[✓] Allow Service: dhcp
[✓] Allow Service: dhcpv6
[✗] FTL Custom Zone Not Detected (https://docs.pi-hole.net/main/prerequisites/#firewalld)
