**redback@raspberrypi**:**~ $** sudo bash -x /opt/pihole/update.sh
+ readonly ADMIN_INTERFACE_GIT_URL=https://github.com/pi-hole/web.git
+ ADMIN_INTERFACE_GIT_URL=https://github.com/pi-hole/web.git
+ readonly PI_HOLE_GIT_URL=https://github.com/pi-hole/pi-hole.git
+ PI_HOLE_GIT_URL=https://github.com/pi-hole/pi-hole.git
+ readonly PI_HOLE_FILES_DIR=/etc/.pihole
+ PI_HOLE_FILES_DIR=/etc/.pihole
+ SKIP_INSTALL=true
+ CHECK_ONLY=false
+ source '/etc/.pihole/automated install/basic-install.sh'
++ set -e
++ export PATH+=:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
++ PATH+=:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
++ trap abort INT QUIT TERM
++ : 0
++ : 1
++ : 255
+++ cat
++ DNS_SERVERS='Google (ECS, DNSSEC);8.8.8.8;8.8.4.4;2001:4860:4860:0:0:0:0:8888;2001:4860:4860:0:0:0:0:8844
OpenDNS (ECS, DNSSEC);208.67.222.222;208.67.220.220;2620:119:35::35;2620:119:53::53
Level3;4.2.2.1;4.2.2.2;;
Comodo;8.26.56.26;8.20.247.20;;
DNS.WATCH (DNSSEC);84.200.69.80;84.200.70.40;2001:1608:10:25:0:0:1c04:b12f;2001:1608:10:25:0:0:9249:d69b
Quad9 (filtered, DNSSEC);9.9.9.9;149.112.112.112;2620:fe::fe;2620:fe::9
Quad9 (unfiltered, no DNSSEC);9.9.9.10;149.112.112.10;2620:fe::10;2620:fe::fe:10
Quad9 (filtered, ECS, DNSSEC);9.9.9.11;149.112.112.11;2620:fe::11;2620:fe::fe:11
Cloudflare (DNSSEC);1.1.1.1;1.0.0.1;2606:4700:4700::1111;2606:4700:4700::1001'
++ installLogLoc=/etc/pihole/install.log
++ coltable=/opt/pihole/COL_TABLE
++ webroot=/var/www/html
++ webInterfaceGitUrl=https://github.com/pi-hole/web.git
++ webInterfaceDir=/var/www/html/admin
++ piholeGitUrl=https://github.com/pi-hole/pi-hole.git
++ PI_HOLE_LOCAL_REPO=/etc/.pihole
++ PI_HOLE_FILES=(list piholeDebug piholeLogFlush setupLCD update version gravity uninstall webpage)
++ PI_HOLE_INSTALL_DIR=/opt/pihole
++ PI_HOLE_CONFIG_DIR=/etc/pihole
++ PI_HOLE_BIN_DIR=/usr/local/bin
++ PI_HOLE_V6_CONFIG=/etc/pihole/pihole.toml
++ fresh_install=true
++ adlistFile=/etc/pihole/adlists.list
++ IPV4_ADDRESS=
++ IPV6_ADDRESS=
++ QUERY_LOGGING=
++ PRIVACY_LEVEL=
++ V6_CONF_MIGRATION_DIR=/etc/pihole/migration_backup_v6
++ '[' -z root ']'
++ r=20
++ c=70
+++ cat
++ PIHOLE_META_PACKAGE_CONTROL_APT='Package: pihole-meta
Version: 0.1
Maintainer: Pi-hole team <adblock@pi-hole.net>
Architecture: all
Description: Pi-hole dependency meta package
Depends: grep,dnsutils,binutils,git,iproute2,dialog,ca-certificates,cron,curl,iputils-ping,psmisc,sudo,unzip,libcap2-bin,dns-root-data,libcap2,netcat-openbsd,procps,jq,lshw,bash-completion'
+++ cat
++ PIHOLE_META_PACKAGE_CONTROL_RPM='Name: pihole-meta
Version: 0.1
Release: 1
License: EUPL
BuildArch: noarch
Summary: Pi-hole dependency meta package
Requires: grep,curl,psmisc,sudo, unzip,jq,git,dialog,ca-certificates, bind-utils, iproute, procps-ng, chkconfig, binutils, cronie, findutils, libcap, nmap-ncat, lshw, bash-completion
%description
%prep
%build
%files
%install
%changelog
* Sun Sep 29 2024 Pi-hole Team - 0.1
- First version being packaged'
++ repair=false
++ runUnattended=false
++ [[ -f /opt/pihole/COL_TABLE ]]
++ source /opt/pihole/COL_TABLE
+++ '[' -t 1 ']'
++++ tput colors
+++ '[' 256 -ge 8 ']'
+++ COL_BOLD='**'**
**+++ COL_ULINE='****'**
**+++ COL_NC='**'
+++ COL_GRAY=''
+++ COL_RED=''
+++ COL_GREEN=''
+++ COL_YELLOW=''
+++ COL_BLUE=''
+++ COL_PURPLE=''
+++ COL_CYAN=''
+++ COL_WHITE='**'**
**+++ COL_BLACK='**'
+++ COL_LIGHT_BLUE=''
+++ COL_LIGHT_GREEN=''
+++ COL_LIGHT_CYAN=''
+++ COL_LIGHT_RED=''
+++ COL_URG_RED='**'**
**+++ COL_LIGHT_PURPLE='****'**
**+++ COL_BROWN='****'**
**+++ COL_LIGHT_GRAY='****'**
**+++ COL_DARK_GRAY=''**
**+++ TICK='[****✓**]'
+++ CROSS='[✗]'
+++ INFO='[i]'
+++ QST='[?]'
+++ DONE=' done!'
+++ OVER='\r'
++ [[ true != true ]]
++ '[' -t 1 ']'
+++ tput colors
++ COL_BOLD='**'**
**++ COL_ULINE='****'**
**++ COL_NC='**'
++ COL_GRAY=''
++ COL_RED=''
++ COL_GREEN=''
++ COL_YELLOW=''
++ COL_BLUE=''
++ COL_PURPLE=''
++ COL_CYAN=''
++ COL_WHITE='**'**
**++ COL_BLACK='**'
++ COL_LIGHT_RED=''
**++ COL_LIGHT_PURPLE='****'**
**++ COL_BROWN='****'**
**++ COL_LIGHT_GRAY='****'**
**++ COL_DARK_GRAY=''**
**++ TICK='[****✓**]'
++ CROSS='[✗]'
++ INFO='[i]'
++ QST='[?]'
++ DONE=' done!'
++ OVER='\r'
+ source /opt/pihole/utils.sh
++ getFTLConfigValue webserver.paths.webroot
++ pihole-FTL --config -q webserver.paths.webroot
++ getFTLConfigValue webserver.paths.webhome
++ pihole-FTL --config -q webserver.paths.webhome
+ ADMIN_INTERFACE_DIR=/var/www/html/admin/
+ readonly ADMIN_INTERFACE_DIR
+ [[ '' == \-\-\c\h\e\c\k\-\o\n\l\y ]]
+ main
+ local 'basicError=\n Unable to complete update, please contact Pi-hole Support'
+ local core_update
+ local web_update
+ local FTL_update
+ core_update=false
+ web_update=false
+ FTL_update=false
+ os_check
+ '[' '' '!=' true ']'
+ local remote_os_domain valid_os valid_version valid_response detected_os detected_version display_warning cmdResult digReturnCode response
+ local piholeNameserver=@ns1.pi-hole.net
+ remote_os_domain=versions.pi-hole.net
++ grep '^ID=' /etc/os-release
++ cut -d = -f2
++ tr -d '"'
+ detected_os=debian
++ grep VERSION_ID /etc/os-release
++ cut -d = -f2
++ tr -d '"'
+ detected_version=12
++ os_check_dig 4 versions.pi-hole.net @ns1.pi-hole.net
++ local protocol=4
++ local domain=versions.pi-hole.net
++ local nameserver=@ns1.pi-hole.net
++ local response
+++ dig -4 +short -t txt versions.pi-hole.net @ns1.pi-hole.net
+++ echo 0
++ response='"Raspbian=11,12 Ubuntu=20,22,23,24 Debian=11,12 Fedora=40,41 CentOS=9,10"
0'
++ echo '"Raspbian=11,12 Ubuntu=20,22,23,24 Debian=11,12 Fedora=40,41 CentOS=9,10"
0'
+ cmdResult='"Raspbian=11,12 Ubuntu=20,22,23,24 Debian=11,12 Fedora=40,41 CentOS=9,10"
0'
+ digReturnCode=0
+ '[' '!' 0 == 0 ']'
++ os_check_dig_response cmdResult
++ local digReply=cmdResult
++ local response
++ response=cmdResult
++ '[' cmdResult == 0 ']'
++ echo true
+ valid_response=true
+ '[' true = false ']'
+ '[' true = true ']'
+ response='"Raspbian=11,12 Ubuntu=20,22,23,24 Debian=11,12 Fedora=40,41 CentOS=9,10"'
+ IFS=' '
+ read -r -a supportedOS
++ echo '"Raspbian=11,12 Ubuntu=20,22,23,24 Debian=11,12 Fedora=40,41 CentOS=9,10"'
++ tr -d '"'
+ for distro_and_versions in "${supportedOS[@]}"
+ distro_part=Raspbian
+ versions_part=11,12
+ [[ DEBIAN =~ RASPBIAN ]]
+ distro_part=Ubuntu
+ versions_part=20,22,23,24
+ [[ DEBIAN =~ UBUNTU ]]
+ distro_part=Debian
+ [[ DEBIAN =~ DEBIAN ]]
+ valid_os=true
+ IFS=,
+ read -r -a supportedVer
+ for version in "${supportedVer[@]}"
+ [[ 12 =~ 11 ]]
+ [[ 12 =~ 12 ]]
+ valid_version=true
+ break
+ break
+ display_warning=false
+ '[' false '!=' false ']'
+ printf ' %b %bSupported OS detected%b\n' '[✓]' '' ''
[✓] Supported OS detected
+ package_manager_detect
+ is_command apt-get
+ local check_command=apt-get
+ command -v apt-get
+ PKG_MANAGER=apt-get
+ UPDATE_PKG_CACHE='apt-get update'
+ PKG_INSTALL='apt-get -qq --no-install-recommends install'
+ PKG_COUNT='apt-get -s -o Debug::NoLocking=true upgrade | grep -c ^Inst || true'
+ PKG_REMOVE='apt-get -y remove --purge'
+ update_package_cache
+ local 'str=Update local cache of available packages'
+ printf ' %b %s...' '[i]' 'Update local cache of available packages'
[i] Update local cache of available packages...+ eval 'apt-get update'
+ printf '%b %b %s\n' '\r' '[✓]' 'Update local cache of available packages'
+ build_dependency_package
+ rm -rf '/tmp/pihole-meta_*'
+ local tempdir
++ mktemp --directory /tmp/pihole-meta_XXXXX
+ tempdir=/tmp/pihole-meta_Pjl1P
+ chmod 0755 /tmp/pihole-meta_Pjl1P
+ pushd /tmp
+ rm -f /tmp/pihole-meta.deb
+ mkdir -p /tmp/pihole-meta_Pjl1P/DEBIAN
+ chmod 0755 /tmp/pihole-meta_Pjl1P/DEBIAN
+ touch /tmp/pihole-meta_Pjl1P/DEBIAN/control
+ echo 'Package: pihole-meta
Version: 0.1
Architecture: all
+ local 'str=Building dependency package pihole-meta.deb'
+ printf ' %b %s...' '[i]' 'Building dependency package pihole-meta.deb'
[i] Building dependency package pihole-meta.deb...+ dpkg-deb --build --root-owner-group /tmp/pihole-meta_Pjl1P pihole-meta.deb
+ printf '%b %b %s\n' '\r' '[✓]' 'Building dependency package pihole-meta.deb'
[✓] Building dependency package pihole-meta.deb
+ popd
+ rm -rf /tmp/pihole-meta_Pjl1P
+ install_dependent_packages
+ local 'str=Installing Pi-hole dependency package'
+ printf ' %b %s...' '[i]' 'Installing Pi-hole dependency package'
[i] Installing Pi-hole dependency package...+ is_command apt-get
+ '[' -f /tmp/pihole-meta.deb ']'
+ eval 'apt-get -qq --no-install-recommends install' /tmp/pihole-meta.deb
+ printf '%b %b %s\n' '\r' '[✗]' 'Installing Pi-hole dependency package'
[✗] Installing Pi-hole dependency package
+ printf ' %b Error: Unable to install Pi-hole dependency package.\n' ''
+ return 1
