Update does not happen on Docker Container re-deployment
On the bottom of the admin page "update available" is blinking red and below the suggestion "to install updates, replace this old container with a fresh updated image". Via Portainer-CE I re-deploy the Container by forcing it to pull it again from pihole/pihole:latest but it won't update.
  • Debian Linux Trixie
  • HP EliteDesk i5-8500T 16GB RAM
  • Docker compose file:
    pihole:
        container_name: pihole
        image: pihole/pihole:latest
        restart: unless-stopped
        network_mode: host
        depends_on:
          unbound:
            condition: service_healthy
        environment:
          TZ: "Europe/Zurich"
          FTLCONF_webserver_api_password: "${PIHOLE_PASSWORD}"
          FTLCONF_dns_upstreams: "172.31.0.3#5335;172.31.0.3#5335"
          FTLCONF_dns_dnssec: "true"
          FTLCONF_dns_bogusPriv: "true"
          FTLCONF_dns_listeningMode: "all"
          FTLCONF_webserver_port: "8080"
          FTLCONF_ntp_ipv4_active: "false"
          FTLCONF_ntp_ipv6_active: "false"
        volumes:
          - /opt/pihole/etc-pihole:/etc/pihole
          - /mnt/nas/docker/pihole/etc-dnsmasq.d:/etc/dnsmasq.d
        cap_add:
          - NET_ADMIN
  • Docker engine version 29.6.0
The Container is not being updated (from the actual 2026.05.0 to the new 2026.06.0)
https://tricorder.pi-hole.net/NJ6Ofa5n/
You are pulling an image, not a container.
Redeploying a container will reuse the already deployed container, which in your case was created from a previous image.
You need to replace the existing container based on 2026.05.0 and deploy a new one based on 2026.06.00.
The necessary steps for plain Docker or docker-compose are described in Docker » Upgrading, e.g.
docker pull pihole/pihole:latest
docker stop pihole
docker rm pihole
docker run [ ... your arguments here ... ]
You need to perform the equivalent actions with Portainer.
This is not a Pi-hole issue.
For some reason, Portainer won't download the new image automatically if you simply stop and restart the stack.
While writing this reply, I just updated one of my instances (which I had forgotten to update last week), using Portainer and it only updates the image if you execute these steps:
  1. stop the stack
  2. go to the "Images" menu and delete the old pihole/pihole:latest image
  3. restart the stack.
Somehow this worked today but did not work a couple of days ago - and I did exactly the same: in Portainer CE I simply re-deployed it by forcing the download of the image.
Anyway: THANKS
