Unsupported RPM based distribution
should complete update without error
pihole -up
[i] Checking for updates...
[i] Pi-hole Core: up to date
[i] FTL: update available
[i] FTL out of date
[i] FTL Checks...
[i] Downloading and Installing FTL...curl: (22) The requested URL returned error: 404 Not Found
Error: URL not found
ALSO:
pihole -r
[✓] Root user check
[✗] Unsupported RPM based distribution
[✓] Your debug token is: 5upe2s2pdy
FedBerry is not a supported OS. Details can be found here
I am piniging our resident Fedora/SEL expert and perhaps he can find some further solutions with you @bcambl
Try the following:
FedBerry Workaround
perhaps...would be great if possible
i revisited that thread you helped me with previously but i'm still getting the error msg:
"unsupported RPM based distribution".
My apologies, there has been changes to the code since our last conversation.
This should hopefully yield better results:
curl -sSL https://install.pi-hole.net | sed s/fedora/fedberry/g | bash
that worked. thanks!!
