Question on this. I go to install pi-hole and it asks me to keep or replace the open ssh package. If I keep it, it hangs. if I replace it I can't login via ssh anymore. Thoughts?
Your question seems to be very different from the current topic.
Also, your comment doesn't give a lot information about your system, source of install, etc.
Can you please open a new topic with your question?
The specific issue I get now is install will fail at being unable to update /etc/.pihole
root@UCK:~# curl -sSL https://install.pi-hole.net | bash
[✓] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[i] SELinux not detected
[i] Existing PHP installation detected : PHP version 5.6.40-0+deb8u12
[i] Checking apt-get for upgraded packages...E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
[i] Checking for / installing Required dependencies for OS Check...
[✓] Checking for grep
[✓] Checking for dnsutils
[✓] Supported OS detected
[i] Checking for / installing Required dependencies for this install script...
[✓] Checking for git
[✓] Checking for iproute2
[✓] Checking for dialog
[✓] Checking for ca-certificates
[i] Using interface: eth0p
[i] IPv4 address: 192.168.1.2/24
[i] Unable to find IPv6 ULA/GUA address
[i] IPv6 address:
[i] Using upstream DNS: Google (ECS, DNSSEC) (8.8.8.8, 8.8.4.4)
[i] Installing StevenBlack's Unified Hosts List
[i] Installing Admin Web Interface
[i] Installing lighttpd
[i] Query Logging on.
[i] Using privacy level: 0
[✗] Check for existing repository in /etc/.pihole
[i] Clone https://github.com/pi-hole/pi-hole.git into /etc/.pihole...
Error: Could not update local repository. Contact support.
Did you do this?
