Uninstalling starts...then just stops
I had Pi-hole running on a Raspberry Pi W2 for just a few mins before I decided to move it to a different box - and that's working great.
I went back to the W2 to uninstall Pi-hole, but it's failing, and I'm not even sure what logs to look at.
This is simply running sudo pihole uninstall and confirming.
After running the uninstall command, I'd expect to confirm the uninstall process, see a confirmation, and then find that Pi-hole is no longer on that system.
##Actual Behaviour:
No error is given, but I'm returned to the CLI and the pi-hole packager remains installed.
billy@raspberrypi:~ $ sudo pihole uninstall
  [?] Are you sure you would like to remove Pi-hole? [y/N] y
  [✓] Root user check
  [i] Removing Pi-hole meta package...billy@raspberrypi:~ $
  • Debian GNU/Linux 12 (bookworm)
  • Raspberry Pi W2
Replace this text with the debug token provided from running pihole -d
Honestly I can just re-flash the OS image, but I'd like to understand what's going on so I can avoid this in a more-consequential circumstance.
Let's take a look at the complete output of the uinstall command. I think this will do it:
EDIT:
sudo bash -x pihole uninstall
