Uninstalled Pihole
[Uninstallation of piHole]
[I ran the uninstall code, and now cannot use the wifi on my phone(Iphone 11) and to a limited extent on my computer. I cant modify anything on the router because I that is one the things that the wifi will not let me access, however youtube works on my computer but not on my phone. However going to change the router settings works on neither.]
[I already uninstalled it, and because I only have limited use of wifi I cannot reinstall either.]
Have you checked to see if you manually put the DNS on the wifi settings on your mobile / PC not just router panel dns
I just set to automatic on my phone and, still unable to connect to the server
I went and bought a usb cable thinking that I can change my router settings through USB, however I cannot find any articles saying that I can. I have also physically powered off the Rasberry Pi, So I don't understand how I cannot access change my router settings.
The solution was to factory reset you router, by holding reset button for 7 seconds. The password and name should be on the side.
