server.upload-dirs = ("/var/cache/lighttpd/uploads")
server.errorlog = "/var/log/lighttpd/error-pihole.log"
server.pid-file = "/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 8082
server.feature-flags = (
"server.h2proto" => "enable",
"server.h2c" => "enable",
"server.graceful-shutdown-timeout" => 5,
# 3
server.http-parseopts = (
"header-strict" => "enable",
"host-strict" => "enable",
"host-normalize" => "enable",
"url-normalize-unreserved" => "enable",
"url-normalize-required" => "enable",
# 5
"url-ctrls-reject" => "enable",
"url-path-2f-decode" => "enable",
"url-path-dotseg-remove" => "enable",
# 8
index-file.names = ("index.php", "index.html")
url.access-deny = ("~", ".inc")
static-file.exclude-extensions = (".php", ".pl", ".fcgi")
alias.url = (
"/javascript" => "/usr/share/javascript",
server.modules = (
"mod_indexfile",
"mod_access",
"mod_alias",
"mod_redirect",
"mod_setenv",
"mod_fastcgi",
"mod_dirlisting",
"mod_staticfile",
# 8
$SERVER["socket"] == "[::]:80" {
# block 1
} # end of $SERVER["socket"] == "[::]:80"
$HTTP["url"] =~ "^/admin/" {
# block 2
server.stream-response-body = 1
accesslog.filename = "/var/log/lighttpd/access-pihole.log"
accesslog.format = "%{%s}t|%h|%V|%r|%s|%b"
fastcgi.server = (
".php" => (
"localhost" => (
"socket" => "/tmp/pihole-php-fastcgi.socket",
"bin-path" => "/usr/bin/php-cgi",
"min-procs" => 0,
"max-procs" => 1,
"bin-environment" => (
"PHP_FCGI_CHILDREN" => "4",
"PHP_FCGI_MAX_REQUESTS" => "10000",
# 2
# 5
"bin-copy-environment" => ("PATH", "SHELL", "USER"),
"broken-scriptfilename" => "enable",
# 7
"X-Frame-Options" => "DENY",
"X-XSS-Protection" => "0",
"X-Content-Type-Options" => "nosniff",
"Content-Security-Policy" => "default-src 'self' 'unsafe-inline';",
# 5
"X-Permitted-Cross-Domain-Policies" => "none",
"Referrer-Policy" => "same-origin",
# 7
$HTTP["url"] =~ "^/admin/\." {
# block 3
url.access-deny = ("")
} # end of $HTTP["url"] =~ "^/admin/\."
$HTTP["url"] =~ "/(teleporter|api_token)\.php$" {
# block 4
$HTTP["referer"] =~ "/admin/settings\.php" {
# block 5
setenv.set-response-header = (
"X-Frame-Options" => "SAMEORIGIN",
} # end of $HTTP["referer"] =~ "/admin/settings\.php"
} # end of $HTTP["url"] =~ "/(teleporter|api_token)\.php$"
} # end of $HTTP["url"] =~ "^/admin/"
else $HTTP["url"] == "/admin" {
# block 6
url.redirect = (
"" => "/admin/",
} # end of $HTTP["url"] == "/admin"
$HTTP["host"] == "pi.hole" {
# block 7
$HTTP["url"] == "/" {
# block 8
url.redirect = (
"" => "/admin/",
} # end of $HTTP["url"] == "/"
} # end of $HTTP["host"] == "pi.hole"
Now, restart lighttpd
sudo systemctl restart lighttpd.service
I can access through this link http://192.168.1.2:8082/admin/. But what is the reason for this "error" on the part of the user or what happened?
I'm not sure.
This should not happen on updates, but I will investigate why your case didn't use the original external.conf
Note:
I think you can restart nginx
too. All should work as expected now.
Should I repeat this procedure after the next update?
That should have fixed the problem.
Under normal circumstances, there is no need to do this again.
Thank you very much for your help and time, I appreciate it very much.
