Unifi UDM + pihole + unbound not return local record for vnet
My setup:
Unifi UDM at 192.168.1.1, 3 vnet, 192.168.2.0/24, 192.168.3.0/24, 192.168.107.0/24
UDM wan DNS: 1.1.1.1
all internal network DNS set to the pihole + unbound ip: 192.168.1.61
Use macbook pro for 2 ssid: one for 192.168.2.0/24, one for 192.168.107.0/24
ssid 192.168.2.0/24 does not return local dns record
ssid 192.168.107.0/24 returns correct local dns record
Return a local (non-public) DNS record
  • Proxmox
  • AMD CPU
One wifi SSID returns local record, another one does not
Not sure how to run pihole -d in proxmox.
I don't think a debug log will show anything because the problem is most likely with your firewall and/or LAN/VLAN routing.
