Unexpected kat.cr on Apple devices
Should I be worried that my new MacBook Pro and my iPhone keep having kat.cr request (when I'm not even on they website)
  • I do not even torrent or go on this website on this device, I might have a kickass tracker on my Synology/Jackett but definitely not on my Mac. (assuming that Kat.cr is kickass torrent)
    |2019-02-18 22:28:59|A|kat.cr|10.0.4.14|Blocked (gravity)|- (0.1ms)|Whitelist|
    |2019-02-18 22:24:23|A|kat.cr|10.0.4.37|Blocked (gravity)|- (0.2ms)|Whitelist|
    |2019-02-18 20:46:26|A|kat.cr|10.0.4.37|Blocked (gravity)|- (0.1ms)|Whitelist|
    |2019-02-17 22:10:13|A|kat.cr|10.0.4.37|Blocked (gravity)|
Since this is a Pi-Hole forum, it would be difficult for us to give you advice on whether this should worry you. It does seem that Pi-Hole is working as intended and blocking this domain found in your gravity list.
ok sorry for the post
