Unbound will not start
Trying to get Unbound running as per (Redirecting...)
Could not get past starting the service.
Did a complete new install
Unbound service starts
Unbound service fails to start
mu18do1n4l
So far:
pi@raspberrypi:~ $ sudo service unbound start
pi@raspberrypi:~ $ dig pi-hole.net @127.0.0.1 -p 5353
; <<>> DiG 9.10.3-P4-Raspbian <<>> pi-hole.net @127.0.0.1 -p 5353
pi@raspberrypi:~ $ sudo journalctl -u unbound.service -b
-- Logs begin at Thu 2016-11-03 11:16:42 MDT, end at Thu 2018-11-08 11:41:20 MST. --
Nov 08 11:36:21 raspberrypi systemd[1]: Starting Unbound DNS server...
Nov 08 11:36:22 raspberrypi package-helper[9588]: /var/lib/unbound/root.key does not exist, copying from /usr/share/dns/root.key
Nov 08 11:36:22 raspberrypi package-helper[9588]: /var/lib/unbound/root.key has content
Nov 08 11:36:22 raspberrypi package-helper[9588]: success: the anchor is ok
Nov 08 11:36:22 raspberrypi systemd[1]: Started Unbound DNS server.
Nov 08 11:36:22 raspberrypi unbound[9594]: [1541702182] unbound[9594:0] error: can't bind socket: Address already in use for ::1
Nov 08 11:36:22 raspberrypi unbound[9594]: [1541702182] unbound[9594:0] fatal error: could not open ports
Nov 08 11:36:22 raspberrypi systemd[1]: unbound.service: Main process exited, code=exited, status=1/FAILURE
Nov 08 11:36:22 raspberrypi systemd[1]: unbound.service: Unit entered failed state.
Nov 08 11:36:22 raspberrypi systemd[1]: unbound.service: Failed with result 'exit-code'.
Nov 08 11:36:22 raspberrypi systemd[1]: unbound.service: Service hold-off time over, scheduling restart.
Nov 08 11:36:22 raspberrypi systemd[1]: Stopped Unbound DNS server.
Nov 08 11:36:22 raspberrypi systemd[1]: Starting Unbound DNS server...
Nov 08 11:36:23 raspberrypi package-helper[9679]: /var/lib/unbound/root.key has content
Nov 08 11:36:23 raspberrypi package-helper[9679]: success: the anchor is ok
Nov 08 11:36:23 raspberrypi systemd[1]: Started Unbound DNS server.
Nov 08 11:36:23 raspberrypi unbound[9688]: [1541702183] unbound[9688:0] error: can't bind socket: Address already in use for ::1
Nov 08 11:36:23 raspberrypi unbound[9688]: [1541702183] unbound[9688:0] fatal error: could not open ports
Nov 08 11:36:23 raspberrypi systemd[1]: unbound.service: Main process exited, code=exited, status=1/FAILURE
Nov 08 11:36:23 raspberrypi systemd[1]: unbound.service: Unit entered failed state.
Nov 08 11:36:23 raspberrypi systemd[1]: unbound.service: Failed with result 'exit-code'.
Nov 08 11:36:23 raspberrypi systemd[1]: unbound.service: Service hold-off time over, scheduling restart.
Nov 08 11:36:23 raspberrypi systemd[1]: Stopped Unbound DNS server.
Nov 08 11:36:23 raspberrypi systemd[1]: Starting Unbound DNS server...
Nov 08 11:36:24 raspberrypi package-helper[9766]: /var/lib/unbound/root.key has content
Nov 08 11:36:24 raspberrypi package-helper[9766]: success: the anchor is ok
Nov 08 11:36:24 raspberrypi systemd[1]: Started Unbound DNS server.
Nov 08 11:36:24 raspberrypi unbound[9773]: [1541702184] unbound[9773:0] error: can't bind socket: Address already in use for ::1
Nov 08 11:36:24 raspberrypi unbound[9773]: [1541702184] unbound[9773:0] fatal error: could not open ports
Nov 08 11:36:24 raspberrypi systemd[1]: unbound.service: Main process exited, code=exited, status=1/FAILURE
Nov 08 11:36:24 raspberrypi systemd[1]: unbound.service: Unit entered failed state.
Nov 08 11:36:24 raspberrypi systemd[1]: unbound.service: Failed with result 'exit-code'.
Nov 08 11:36:24 raspberrypi systemd[1]: unbound.service: Service hold-off time over, scheduling restart.
Nov 08 11:36:24 raspberrypi systemd[1]: Stopped Unbound DNS server.
Nov 08 11:36:24 raspberrypi systemd[1]: Starting Unbound DNS server...
Nov 08 11:36:24 raspberrypi package-helper[9832]: /var/lib/unbound/root.key has content
Nov 08 11:36:24 raspberrypi package-helper[9832]: success: the anchor is ok
Nov 08 11:36:24 raspberrypi unbound[9838]: [1541702184] unbound[9838:0] error: can't bind socket: Address already in use for ::1
Nov 08 11:36:24 raspberrypi unbound[9838]: [1541702184] unbound[9838:0] fatal error: could not open ports
Nov 08 11:36:25 raspberrypi systemd[1]: Stopped Unbound DNS server.
Nov 08 11:36:25 raspberrypi systemd[1]: Starting Unbound DNS server...
Nov 08 11:36:25 raspberrypi package-helper[9894]: /var/lib/unbound/root.key has content
Nov 08 11:36:25 raspberrypi package-helper[9894]: success: the anchor is ok
Nov 08 11:36:25 raspberrypi systemd[1]: Started Unbound DNS server.
Nov 08 11:36:25 raspberrypi unbound[9899]: [1541702185] unbound[9899:0] error: can't bind socket: Address already in use for ::1
Nov 08 11:36:25 raspberrypi unbound[9899]: [1541702185] unbound[9899:0] fatal error: could not open ports
Nov 08 11:36:25 raspberrypi systemd[1]: unbound.service: Main process exited, code=exited, status=1/FAILURE
Nov 08 11:36:25 raspberrypi systemd[1]: unbound.service: Unit entered failed state.
Nov 08 11:36:25 raspberrypi systemd[1]: unbound.service: Failed with result 'exit-code'.
Nov 08 11:36:25 raspberrypi systemd[1]: unbound.service: Service hold-off time over, scheduling restart.
Nov 08 11:36:25 raspberrypi package-helper[9955]: /var/lib/unbound/root.key has content
Nov 08 11:36:25 raspberrypi package-helper[9955]: success: the anchor is ok
lines 1-62
What are the outputs of these two commands:
sudo service unbound status
cat /etc/unbound/unbound.conf.d/pi-hole.conf
pi@raspberrypi:~ $ sudo service unbound status
   Active: failed (Result: exit-code) since Thu 2018-11-08 11:38:59 MST; 1h 3min ago
     Docs: man:unbound(8)
  Process: 10375 ExecStart=/usr/sbin/unbound -d $DAEMON_OPTS (code=exited, status=1/FAILURE)
  Process: 10368 ExecStartPre=/usr/lib/unbound/package-helper root_trust_anchor_update (code=exited, status=0/SUCCESS)
  Process: 10364 ExecStartPre=/usr/lib/unbound/package-helper chroot_setup (code=exited, status=0/SUCCESS)
 Main PID: 10375 (code=exited, status=1/FAILURE)
Nov 08 11:38:59 raspberrypi systemd[1]: unbound.service: Failed with result 'exit-code'.
Nov 08 11:38:59 raspberrypi systemd[1]: unbound.service: Service hold-off time over, scheduling restart.
Nov 08 11:38:59 raspberrypi systemd[1]: Stopped Unbound DNS server.
Nov 08 11:38:59 raspberrypi systemd[1]: unbound.service: Start request repeated too quickly.
Nov 08 11:38:59 raspberrypi systemd[1]: Failed to start Unbound DNS server.
Nov 08 11:38:59 raspberrypi systemd[1]: unbound.service: Unit entered failed state.
pi@raspberrypi:~ $ cat /etc/unbound/unbound.conf.d/pi-hole.conf
server:
    logfile: "/var/log/unbound/unbound.log"
    verbosity: 0
    port: 5353
    do-ip4: yes
    do-udp: yes
    do-tcp: yes
    do-ip6: no
    root-hints: "/var/lib/unbound/root.hints"
    # Trust glue only if it is within the servers authority
    harden-glue: yes
    # Require DNSSEC data for trust-anchored zones, if such data is absent, the        zone becomes BOGUS
    harden-dnssec-stripped: yes
    # Don't use Capitalization randomization as it known to cause DNSSEC issues        sometimes
    # see https://discourse.pi-hole.net/t/unbound-stubby-or-dnscrypt-proxy/9378        for further details
    use-caps-for-id: no
    # Suggested by the unbound man page to reduce fragmentation reassembly probl        ems
    edns-buffer-size: 1472
    # TTL bounds for cache
    cache-min-ttl: 3600
    cache-max-ttl: 86400
    prefetch: yes
    # One thread should be sufficient, can be increased on beefy machines
    num-threads: 1
    # Ensure kernel buffer is large enough to not loose messages in traffic spik        es
    so-rcvbuf: 1m
    private-address: 10.0.0.0/8
    private-address: fd00::/8
    private-address: fe80::/10
pi@raspberrypi:~ $ cat /var/lib/unbound/root.hints
cat: /var/lib/unbound/root.hints: No such file or directory
This file should not be empty. This is the directory of the root name servers.
Double check your command syntax cat /var/lib/unbound/root.hints and if still empty, then run this command and paste in the code below, exit, save and restart unbound.
sudo nano /var/lib/unbound/root.hints
;       This file holds the information on root name servers needed to
;       initialize cache of Internet domain name servers
;       (e.g. reference this file in the "cache  .  <file>"
;       configuration file of BIND domain name servers).
;       This file is made available by InterNIC
;       under anonymous FTP as
;           file                /domain/named.cache
;           on server           FTP.INTERNIC.NET
;       -OR-                    RS.INTERNIC.NET
;       last update:     October 24, 2018
;       related version of root zone:     2018102401
; FORMERLY NS.INTERNIC.NET
.                        3600000      NS    A.ROOT-SERVERS.NET.
A.ROOT-SERVERS.NET.      3600000      A     198.41.0.4
A.ROOT-SERVERS.NET.      3600000      AAAA  2001:503:ba3e::2:30
; FORMERLY NS1.ISI.EDU
.                        3600000      NS    B.ROOT-SERVERS.NET.
B.ROOT-SERVERS.NET.      3600000      A     199.9.14.201
B.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:200::b
; FORMERLY C.PSI.NET
.                        3600000      NS    C.ROOT-SERVERS.NET.
C.ROOT-SERVERS.NET.      3600000      A     192.33.4.12
C.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:2::c
; FORMERLY TERP.UMD.EDU
.                        3600000      NS    D.ROOT-SERVERS.NET.
D.ROOT-SERVERS.NET.      3600000      A     199.7.91.13
D.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:2d::d
; FORMERLY NS.NASA.GOV
.                        3600000      NS    E.ROOT-SERVERS.NET.
E.ROOT-SERVERS.NET.      3600000      A     192.203.230.10
E.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:a8::e
; FORMERLY NS.ISC.ORG
.                        3600000      NS    F.ROOT-SERVERS.NET.
F.ROOT-SERVERS.NET.      3600000      A     192.5.5.241
F.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:2f::f
; FORMERLY NS.NIC.DDN.MIL
.                        3600000      NS    G.ROOT-SERVERS.NET.
G.ROOT-SERVERS.NET.      3600000      A     192.112.36.4
G.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:12::d0d
; FORMERLY AOS.ARL.ARMY.MIL
.                        3600000      NS    H.ROOT-SERVERS.NET.
H.ROOT-SERVERS.NET.      3600000      A     198.97.190.53
H.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:1::53
; FORMERLY NIC.NORDU.NET
.                        3600000      NS    I.ROOT-SERVERS.NET.
I.ROOT-SERVERS.NET.      3600000      A     192.36.148.17
I.ROOT-SERVERS.NET.      3600000      AAAA  2001:7fe::53
; OPERATED BY VERISIGN, INC.
.                        3600000      NS    J.ROOT-SERVERS.NET.
J.ROOT-SERVERS.NET.      3600000      A     192.58.128.30
J.ROOT-SERVERS.NET.      3600000      AAAA  2001:503:c27::2:30
; OPERATED BY RIPE NCC
.                        3600000      NS    K.ROOT-SERVERS.NET.
K.ROOT-SERVERS.NET.      3600000      A     193.0.14.129
K.ROOT-SERVERS.NET.      3600000      AAAA  2001:7fd::1
; OPERATED BY ICANN
.                        3600000      NS    L.ROOT-SERVERS.NET.
L.ROOT-SERVERS.NET.      3600000      A     199.7.83.42
L.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:9f::42
; OPERATED BY WIDE
.                        3600000      NS    M.ROOT-SERVERS.NET.
M.ROOT-SERVERS.NET.      3600000      A     202.12.27.33
M.ROOT-SERVERS.NET.      3600000      AAAA  2001:dc3::35
; End of file
Problem solved . I did not do that step in the documentation because it said it was optional and only needed to be done every six months.
Thanks for your time jfb
We'll have to take a look at that part of the documentation and see if it can be improved. Glad you're up and running now.
Thanks for this, I'm a newb with the linux console but have a second pi to play with. What about backing up the created cache? I have no idea where it even is.
Regards,
Brian
I mean the cache that from Unbound that will be cleared after each restart
Stretch- lite
Brian
