Unbound : unable to issue
I formatted and start over a few time, as I keep having mix results.
at this stage unbound don't seems to work at all but when I go back to cloudflare, PiHole is resolving again.
I did follow the instruction on my Raspberry Pi 4 and my conf should pretty much look like this
server:
    # logfile: "/var/log/unbound/unbound.log"
    verbosity: 0
    interface: 127.0.0.1
    port: 5335
    do-ip4: yes
    do-udp: yes
    do-tcp: yes
    do-ip6: yes
    prefer-ip6: yes
    root-hints: "/var/lib/unbound/root.hints"
    # Trust glue only if it is within the server's authority
    harden-glue: yes
    harden-dnssec-stripped: yes
    use-caps-for-id: no
    # Suggested by the unbound man page to reduce fragmentation reassembly problems
    edns-buffer-size: 1472
    prefetch: yes
    # One thread should be sufficient, can be increased on beefy machines. In reality for most users running on small networks or on a single machine, it should be unnecessary to seek performance enhancement by increasing num-threads above 1.
    num-threads: 1
    so-rcvbuf: 1m
    private-address: 10.0.0.0/8
    private-address: fd00::/8
    private-address: fe80::/10
PS: I tried to set "prefer-ip6" to no to test, but same result.
Firewall everything is running fine with my second PiHole (DoT this time)
all firewall are in the same IP group
(GateWay : UniFi UDM PRO)
Local IN
Allow DNS Servers out > Accept > Source GROUP DNS SERVER > DESTINATION * Groups: Local VLAN, DNS Port
Allow DNS Servers out > Accept > Source GROUP LOCALVLAN > DESTINATION * Groups: DNSSERVER, DNS Port
Drop Block DNS Serverst > Accept > Source GROUP DNSPORT
IPV6 Rule
2500 Accept Established Accept All
2501 Drop invalid Drop All
DNSPORT : 5353, 53
LOCALVLAN : 192.168.1.0/24, 192.168.3.0/24,192.168.4.0/24,192.168.7.0/24
DNSSERVER : 1.1.1.1, 1.0.0.1, 192.168.1.59, 192.168.1.149
PiHole settings :
With UnBound (resolver)
127.0.0.1#5335
::1#5335
without (resolver)
1.1.1.1
1.0.0.1
Listen on all interface
Never Forward non-FDQNs
Never Forward reverse lookups for prive IP ranges
Try adding log output to unbound to see what's going on:
Add in /etc/unbound/unbound.conf.d/pi-hole.conf
    log-time-ascii: yes
    verbosity: 2
Create the file and change permissions to unbound user
touch /var/log/unbound/unbound.log
sudo chown unbound /var/log/unbound/unbound.log
restart unbound
sudo service unbound restart
And look in the log
cat /var/log/unbound/unbound.log
Independent of your unbound issue, that doesn't look right:
I would try (bold what I changed)
Allow DNS Servers out > Accept > Source GROUP DNS SERVER > DESTINATION Groups: DNS Port
Allow DNS to DNS Servers > Accept > Source GROUP LOCALVLAN > DESTINATION Groups: DNSSERVER, DNS Port
Drop all other DNS Servers > Drop > Source GROUP LOCALVLAN > DESTINATION GROUP DNSPORT
DNSPORT : 5353, 53
Thank you, I add the log in the config file
but I can do the second step
No such file or directory
I restarted unbound thinking the config file would create the actual log file but it don't seems to work this way.
Should I just create the file so? (can't seems to be able to create a file with nano /var/log/unbound/unbound.log too)
Try
sudo touch /var/log/unbound/unbound.log
pi@raspberrypi:~ $ sudo touch /var/log/unbound/unbound.log
touch: cannot touch '/var/log/unbound/unbound.log': No such file or directory
pi@raspberrypi:~ $
pi@raspberrypi:~ $ sudo su
root@raspberrypi:/home/pi# chown unbound /var/log/unbound/unbound.log
chown: cannot access '/var/log/unbound/unbound.log': No such file or directory
sudo mkdir /var/log/unbound
Thank for your help, I give up. for months I didn't managed to have unbound working, I add the log file in unbound config but it didn't log anything.... anyway , just keep CloudFlare, I guess it's not that bad.
PS when deleting / re installing unbound, I release I always gave an error
Linux raspberrypi 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l
(Reading database ... 41248 files and directories currently installed.)
Removing unbound (1.9.0-2+deb10u2) ...
Processing triggers for man-db (2.8.5-2) ...
pi@raspberrypi:~ $ sudo apt install unbound
Reading package lists... Done
Building dependency tree
The following package was automatically installed and is no longer required:
  rpi-eeprom-images
Use 'sudo apt autoremove' to remove it.
Suggested packages:
  apparmor
  unbound
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 671 kB of archives.
After this operation, 3,637 kB of additional disk space will be used.
Get:1 http://ftp.acc.umu.se/mirror/raspbian/raspbian buster/main armhf unbound armhf 1.9.0-2+deb10u2 [671 kB]
Fetched 671 kB in 1s (776 kB/s)
Selecting previously unselected package unbound.
(Reading database ... 41216 files and directories currently installed.)
Preparing to unpack .../unbound_1.9.0-2+deb10u2_armhf.deb ...
Unpacking unbound (1.9.0-2+deb10u2) ...
Setting up unbound (1.9.0-2+deb10u2) ...
Job for unbound.service failed because the control process exited with error code.
See "systemctl status unbound.service" and "journalctl -xe" for details.
invoke-rc.d: initscript unbound, action "restart" failed.
โ— unbound.service - Unbound DNS server
   Active: activating (auto-restart) (Result: exit-code) since Sat 2020-07-11 20:18:58 BST; 24ms ago
     Docs: man:unbound(8)
  Process: 1352 ExecStartPre=/usr/lib/unbound/package-helper chroot_setup (code=exited, status=1/FAILURE)
  Process: 1355 ExecStartPre=/usr/lib/unbound/package-helper root_trust_anchor_update (code=exited, status=1/FAILURE)
  Process: 1358 ExecStart=/usr/sbin/unbound -d $DAEMON_OPTS (code=exited, status=1/FAILURE)
 Main PID: 1358 (code=exited, status=1/FAILURE)
Processing triggers for systemd (241-7~deb10u4+rpi1) ...
pi@raspberrypi:~ $
Not even the start of the unbound service?
What is the output of
sudo unbound-checkconf
and
sudo service unbound status
I have a few error, it's probably not installed properly at the first place
pi@raspberrypi:~ $ sudo unbound-checkconf
/etc/unbound/unbound.conf.d/pi-hole.conf:13: error: expected yes or no.
read /etc/unbound/unbound.conf failed: 1 errors in configuration file
pi@raspberrypi:~ $
file
pi@raspberrypi:~ $ sudo service unbound status
   Loaded: loaded (/lib/systemd/system/unbound.service; enabled; vendor preset: enabl   Active: failed (Result: exit-code) since Sat 2020-07-11 20:19:00 BST; 2min 15s ago     Docs: man:unbound(8)
  Process: 1448 ExecStartPre=/usr/lib/unbound/package-helper chroot_setup (code=exite  Process: 1451 ExecStartPre=/usr/lib/unbound/package-helper root_trust_anchor_update  Process: 1454 ExecStart=/usr/sbin/unbound -d $DAEMON_OPTS (code=exited, status=1/FA Main PID: 1454 (code=exited, status=1/FAILURE)
Jul 11 20:19:00 raspberrypi systemd[1]: unbound.service: Service RestartSec=100ms expJul 11 20:19:00 raspberrypi systemd[1]: unbound.service: Scheduled restart job, restaJul 11 20:19:00 raspberrypi systemd[1]: Stopped Unbound DNS server.
Jul 11 20:19:00 raspberrypi systemd[1]: unbound.service: Start request repeated too qJul 11 20:19:00 raspberrypi systemd[1]: unbound.service: Failed with result 'exit-codJul 11 20:19:00 raspberrypi systemd[1]: Failed to start Unbound DNS server.
lines 1-15/15 (END)...skipping...
Unbound doesn't start because of an error at line 13 in /etc/unbound/unbound.conf.d/pi-hole.conf
What's at line 13 in your current config?
Additionally:
Please post the output of:
cat /var/lib/unbound/root.hints
I removed /etc/unbound/unbound.conf.d/pi-hole.conf and wrote a new file (config below)
server:
    verbosity: 0
    port: 5335
    do-ip4: yes
    do-udp: yes
    do-tcp: yes
    do-ip6: yes
    prefer-ip6: yes
    harden-glue: yes
    use-caps-for-id: no
    prefetch: yes
    num-threads: 1
    so-rcvbuf: 1m
I still get the error in the config
/etc/unbound/unbound.conf.d/pi-hole.conf:17: error: expected yes or no.
pi@raspberrypi:~ $ cat /var/lib/unbound/root.hints
cat: /var/lib/unbound/root.hints: No such file or directory
pi@raspberrypi:~ $
prefer-ip6: tes
This file does not exist. Have a look at the guide again how to download:
(It's right before " Configure unbound")
This is the problem:
Annotation 2020-07-11 124543
Edit: And really, you don't need prefer ipv6 at all, it's on the same device as Pi-hole and will be accessed via the localhost interface anyways.
I updating to ยซ no ยป now but I do have a natif IPv6
Doesn't matter, you use 127.0.0.1:5335 as the address for Pi-hole to connect to unbound.
I changed to no, just checking I can still refer IPv6 to ::1#5335 right? (I added 127.0.0.1:5335)
Also I did this again just in case I forgot during the last reformat
wget -O root.hints https://www.internic.net/domain/named.root
sudo mv root.hints /var/lib/unbound/
but I still get this
/var/lib/unbound/root.key: No such file or directory
[1594497037] unbound-checkconf[2260:0] fatal error: auto-trust-anchor-file: "/var/lib/unbound/root.key" does not exist
Shorted (cat /var/lib/unbound/root.hints)
;       This file holds the information on root name servers needed to
;       initialize cache of Internet domain name servers
;       (e.g. reference this file in the "cache  .  <file>"
;       configuration file of BIND domain name servers).
;       This file is made available by InterNIC
;       under anonymous FTP as
;           file                /domain/named.cache
;           on server           FTP.INTERNIC.NET
;       -OR-                    RS.INTERNIC.NET
;       last update:     June 08, 2020
;       related version of root zone:     2020060801
; FORMERLY NS.INTERNIC.NET
.                        3600000      NS    A.ROOT-SERVERS.NET.
A.ROOT-SERVERS.NET.      3600000      A     198.41.0.4
A.ROOT-SERVERS.NET.      3600000      AAAA  2001:503:ba3e::2:30
; FORMERLY NS1.ISI.EDU
.                        3600000      NS    B.ROOT-SERVERS.NET.
B.ROOT-SERVERS.NET.      3600000      A     199.9.14.201
B.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:200::b
; FORMERLY C.PSI.NET
.                        3600000      NS    C.ROOT-SERVERS.NET.
C.ROOT-SERVERS.NET.      3600000      A     192.33.4.12
C.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:2::c
; FORMERLY TERP.UMD.EDU
.                        3600000      NS    D.ROOT-SERVERS.NET.
D.ROOT-SERVERS.NET.      3600000      A     199.7.91.13
D.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:2d::d
; FORMERLY NS.NASA.GOV
.                        3600000      NS    E.ROOT-SERVERS.NET.
E.ROOT-SERVERS.NET.      3600000      A     192.203.230.10
E.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:a8::e
; FORMERLY NS.ISC.ORG
.                        3600000      NS    F.ROOT-SERVERS.NET.
F.ROOT-SERVERS.NET.      3600000      A     192.5.5.241
F.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:2f::f
; FORMERLY NS.NIC.DDN.MIL
.                        3600000      NS    G.ROOT-SERVERS.NET.
G.ROOT-SERVERS.NET.      3600000      A     192.112.36.4
G.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:12::d0d
; FORMERLY AOS.ARL.ARMY.MIL
.                        3600000      NS    H.ROOT-SERVERS.NET.
H.ROOT-SERVERS.NET.      3600000      A     198.97.190.53
H.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:1::53
; FORMERLY NIC.NORDU.NET
.                        3600000      NS    I.ROOT-SERVERS.NET.
I.ROOT-SERVERS.NET.      3600000      A     192.36.148.17
I.ROOT-SERVERS.NET.      3600000      AAAA  2001:7fe::53
; OPERATED BY VERISIGN, INC.
.                        3600000      NS    J.ROOT-SERVERS.NET.
J.ROOT-SERVERS.NET.      3600000      A     192.58.128.30
J.ROOT-SERVERS.NET.      3600000      AAAA  2001:503:c27::2:30
; OPERATED BY RIPE NCC
.                        3600000      NS    K.ROOT-SERVERS.NET.
K.ROOT-SERVERS.NET.      3600000      A     193.0.14.129
K.ROOT-SERVERS.NET.      3600000      AAAA  2001:7fd::1
; OPERATED BY ICANN
.                        3600000      NS    L.ROOT-SERVERS.NET.
L.ROOT-SERVERS.NET.      3600000      A     199.7.83.42
L.ROOT-SERVERS.NET.      3600000      AAAA  2001:500:9f::42
; OPERATED BY WIDE
.                        3600000      NS    M.ROOT-SERVERS.NET.
M.ROOT-SERVERS.NET.      3600000      A     202.12.27.33
M.ROOT-SERVERS.NET.      3600000      AAAA  2001:dc3::35
; End of filepi@raspberrypi:~ $
For the root.key:
sudo -u unbound unbound-anchor
root.hints looks good now.
Why would you? They are both loopbacks.
