Unbound stopped working after setting up wireguard
I've been running PiHole with unbound for a few years now on a Pi Zero W.
I wanted to use my PiHole on my iPhone so I installed and set up wireguard using this guide from the Pi-Hole docs. I also set up ufw following this post on the forum, as well as this blog post.
After the setup everything is working fine except unbound. I removed and reinstalled unbound following this guide in the Pi-Hole docs.
PiHole works fine if I set my Upstream resolver to Quad9.
I do not think ufw is the problem. If I run sudo ufw disable and reboot the pi the problem remains.
Relevant info:
The output of dig fail01.dnssec.works @127.0.0.1 -p 5335 is
; <<>> DiG 9.16.42-Raspbian <<>> fail01.dnssec.works @127.0.0.1 -p 5335
;; ->>HEADER<<- opcode: QUERY, status: REFUSED, id: 26082
;; flags: qr rd ad; QUERY: 0, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0
;; WARNING: recursion requested but not available
;; Query time: 0 msec
;; WHEN: Sun Sep 03 11:35:11 CEST 2023
;; MSG SIZE  rcvd: 12
The output of dig dnssec.works @127.0.0.1 -p 5335 is
; <<>> DiG 9.16.42-Raspbian <<>> dnssec.works @127.0.0.1 -p 5335
;; ->>HEADER<<- opcode: QUERY, status: REFUSED, id: 14779
;; WHEN: Sun Sep 03 11:36:19 CEST 2023
The output of sudo ufw status is
Status: active
To                         Action      From
22/tcp                     ALLOW       192.168.178.0/24
80/tcp                     ALLOW       192.168.178.0/24
53/tcp                     ALLOW       192.168.178.0/24
53/udp                     ALLOW       192.168.178.0/24
4711/tcp                   ALLOW       127.0.0.0/8
47111/udp                  ALLOW       Anywhere
53/tcp                     ALLOW       10.100.0.0/24
53/udp                     ALLOW       10.100.0.0/24
Anywhere on eth0           ALLOW FWD   Anywhere on wg0
Unbound resolving requests nomrally
Unbound refuses to resolve requests
https://tricorder.pi-hole.net/KhHYHnr3/
Up log verbosity and check the journals when running dig:
increasing the verbosity to 4 shows that queries seem to come from the Pi.holes IP address on a random port.
Sep 06 23:06:19 pihole unbound[485]: [1694034379] unbound[485:0] debug: refused query from ip4 192.168.178.74 port 36505 (len 16)
Sep 06 23:06:36 pihole unbound[485]: [1694034395] unbound[485:0] debug: refused query from ip4 192.168.178.74 port 48926 (len 16)
Sep 06 23:09:38 pihole unbound[485]: [1694034578] unbound[485:0] debug: refused query from ip4 192.168.178.74 port 58656 (len 16)
shouldn't those say something like query from ip4 127.0.0.1 port 5335?
Yes for the IP.
No for the port.
The port displayed in the journals is the source port initiated from the client.
And should connect to destination port 5335 where unbound should be listening.
unbound will reply to the same source port that was initiated by the client.
But if configured unbound according to the official guide, unbound shouldn't be listening or replying to any IP's besides the ones on the loopback interface named lo:
pi@ph5b:~ $ less /etc/unbound/unbound.conf.d/pi-hole.conf
    interface: 127.0.0.1
    port: 5335
pi@ph5b:~ $ sudo ss -nltup sport 5335
Netid  State   Recv-Q  Send-Q    Local Address:Port     Peer Address:Port  Process
udp    UNCONN  0       0             127.0.0.1:5335          0.0.0.0:*      users:(("unbound",pid=19820,fd=3))
tcp    LISTEN  0       256           127.0.0.1:5335          0.0.0.0:*      users:(("unbound",pid=19820,fd=4))
pi@ph5b:~ $ ip -br link show lo
lo               UNKNOWN        00:00:00:00:00:00 <LOOPBACK,UP,LOWER_UP>
pi@ph5b:~ $ ip -br address show lo
lo               UNKNOWN        127.0.0.1/8 ::1/128
What does below output?
sudo rgrep -v '^ *#\|^ *$' /etc/unbound/unbound.conf*
pi@pihole:~ $ sudo rgrep -v '^ *#\|^ *$' /etc/unbound/unbound.conf*
/etc/unbound/unbound.conf.d/pi-hole.conf:    logfile: "/var/log/unbound/unbound.log"
/etc/unbound/unbound.conf.d/pi-hole.conf:    verbosity: 5
/etc/unbound/unbound.conf.d/pi-hole.conf:    edns-buffer-size: 1232
all the other commands output the same as you posted
This would suggest that either your unbound isn't configured as a recursive resolver, or unbound itself is having difficulties to perform the recursion.
Your unbound.conf* configuration as shared above would rule out the former (and so would your previous successful use of unbound, prior to installing Wireguard).
That may suggest that Wireguard's installation introduced some quirk that prevents unbound to operate correctly.
The most likely source of interference would be your firewall rules.
As stopping your ufw firewall did not seem to affect your observation, it could be the PostUp/PreDown rules for Wireguard that may be causing you troubles, especially since you seem to have been mixing information from Digital Ocean's and Pi-hole's own
recommendations for setting up Wireguard. In addition, both of those would manipulate iptables/nft directly, and I'm unsure how that would impact a firewall frontend like ufw.
This does not seem like a Pi-hole issue, but if you'd share your Wireguard's PostUp/PreDown sections, I see if I can spot something obvious.
PostUp = nft add table ip wireguard; nft add chain ip wireguard wireguard_chain {type nat hook postrouting priority srcnat\; policy accept\;}; nft add rule ip wireguard wireguard_chain counter packets 0 bytes 0 masquerade; nft add table ip6 wireguard; nft add chain ip6 wireguard wireguard_chain {type nat hook postrouting priority srcnat\; policy accept\;}; nft add rule ip6 wireguard wireguard_chain counter packets 0 bytes 0 masquerade
PostUp = ufw route allow in on wg0 out on eth0
PostUp = iptables -t nat -I POSTROUTING -o eth0 -j MASQUERADE
PreDown = ufw route delete allow in on wg0 out on eth0
PreDown = iptables -t nat -D POSTROUTING -o eth0 -j MASQUERADE
PostDown = nft delete table ip wireguard; nft delete table ip6 wireguard
