Unbound SERVFAIL results only
Your new debug log also shows your router is using itself as DNS server.
Look at the dns-server: 192.168.1.1 line:
   Timeout: 10 seconds
   * Received 300 bytes from eth0:192.168.1.1
     Offered IP address: 192.168.1.158
     Server IP address: 192.168.1.1
     Relay-agent IP address: N/A
     BOOTP server: (empty)
     BOOTP file: (empty)
     DHCP options:
      Message type: DHCPOFFER (2)
      lease-time: 43200 ( 12h )
      renewal-time: 21600 ( 6h )
      rebinding-time: 37800 ( 10h 30m )
      netmask: 255.255.255.0
      broadcast: 192.168.1.255
      router: 192.168.1.1
      domain-name: "lan"
      --- end of options ---
Edit:
If you are sure you edited the DNS on the correct place, maybe you need to renew the DHCP lease for you Pi-hole device (current lease time is 12h).
You need to set Pi-hole as DNS server on DHCP settings.
Note:
I don't have a device using OpenWRT, so I can't tell what is the correct page.
I tried to disable my DHCP server but I've lost access to my Openwrt router
I'll try to troubleshoot it. I'll learn as I go along. I'm really newbie here.
My Wifi interface if up. But i cannot keep connected. I'm going to test it over LAN.
I'll return as soon as get back access.
Sorry for my absolutely lack of skills.
Have a look at this: https://tricorder.pi-hole.net/GBrv9hxM/
I believe it's done. But we never know :smile::
I saw much better speed response times already. Also, http://pi.hole is now being resolved on any device inside my network.
PS: Spoke too soon. Just received a warning from pi-hole diagnosis:
DNSMASQ_WARN Warning in dnsmasq core:
no address range available for DHCP request via lo
@rdwebdesign I suspect that the last provided token is about to expire.
So, I took the liberty to provide a new one.
https://tricorder.pi-hole.net/BPqwRfkF/
