[✓] udp:0.0.0.0:53 is in use by pihole-FTL
udp:127.0.0.1:5335 is in use by unbound
[✓] udp:*:53 is in use by pihole-FTL
tcp:127.0.0.1:5335 is in use by unbound
[✓] tcp:0.0.0.0:53 is in use by pihole-FTL
tcp:127.0.0.1:8953 is in use by unbound
[✓] tcp:0.0.0.0:80 is in use by lighttpd
[✓] tcp:127.0.0.1:4711 is in use by pihole-FTL
[✓] tcp:[::1]:4711 is in use by pihole-FTL
[✓] tcp:[::]:53 is in use by pihole-FTL
[✓] tcp:[::]:80 is in use by lighttpd
Note:
the web interface is also working and running on port 80:
*** [ DIAGNOSING ]: Dashboard headers
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
A plain vanilla dig directed to an IP address without a port goes on port 53. Your Pi-hole is on port 53, and it answered.
Unseen to the requesting client, Pi-hole sends an unblocked and uncached request to its configured upstream server (in this case unbound) for resolution to an IP.
To test unbound directly from the host OS, you need to add a port:
