Recursive DNS using Unbound should work but it doesn't.
Operating System (Family and Version) Raspberry Pi 5 (Bookworm)
Hardware Raspberry Pi 5
ASUS EBG19P Router
Vodafone THG3000 modem/Router with everything possible turned off so that it routes through to the ASUS without interference.
No Docker
I keep getting a SERVFAIL response. As far as I can tell one of the servers in the chain that Unbound is contacting is refusing to answer the request.
Any help would be much appriciated.
SERVFAIL is pretty generic.
You have to determine if its Pi-hole or Unbound generating this return code.
You can do that by inspecting the Pi-hole and Unbound logs.
Some hints to go about below:
Also make sure date/time on the host is correct for DNSSEC validation to succeed:
