The issue I am facing:
Getting an SERVFAIL on unbound with pi hole installed
Details about my system:
raspberry pi 4 (4gb)
I've installed Unbound following the official documentation
When I use the dig command
dig pi-hole.net 127.0.0.1 -p 5335
I get
; <<>> DiG 9.16.37-Debian <<>> pi-hole.net @127.0.0.1 -p 5335
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 7704
;pi-hole.net. IN A
;; Query time: 0 msec
;; WHEN: Sat May 06 12:43:51 PDT 2023
;; MSG SIZE rcvd: 40
Oddly enough all domains get forwarded when setup on Pi hole just nothing caches. Also dig reads no error when set to just 127.0.0.1 without the port
jfb
May 6, 2023, 8:00pm
2
What is the complete output of the following command from the Pi terminal:
/etc/unbound/unbound.conf.d/root-auto-trust-anchor-file.conf: auto-trust-anchor-file: "/var/lib/unbound/root.key"
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:forward-zone:
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf: name: "."
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf: forward-addr: 2600:6c51:4c3f:7159::1
/etc/unbound/unbound.conf.d/pi-hole.conf: verbosity: 0
/etc/unbound/unbound.conf.d/pi-hole.conf: interface: 127.0.0.1
/etc/unbound/unbound.conf.d/pi-hole.conf: port: 5335
/etc/unbound/unbound.conf.d/pi-hole.conf: do-ip4: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: do-udp: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: do-tcp: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: do-ip6: no
/etc/unbound/unbound.conf.d/pi-hole.conf: prefer-ip6: no
/etc/unbound/unbound.conf.d/pi-hole.conf: harden-glue: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: harden-dnssec-stripped: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: use-caps-for-id: no
/etc/unbound/unbound.conf.d/pi-hole.conf: edns-buffer-size: 1232
/etc/unbound/unbound.conf.d/pi-hole.conf: prefetch: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: num-threads: 1
/etc/unbound/unbound.conf.d/pi-hole.conf: so-rcvbuf: 1m
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: 192.168.0.0/16
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: 169.254.0.0/16
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: 172.16.0.0/12
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: 10.0.0.0/8
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: fd00::/8
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: fe80::/10
jfb
May 6, 2023, 8:21pm
4
Edit file /etc/resolvconf.conf and comment out the last line which should then read:
#unbound_conf=/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf
Delete the unwanted unbound configuration file:
sudo rm /etc/unbound/unbound.conf.d/resolvconf_resolvers.conf
Restart unbound:
sudo service unbound restart
this is the new output of the dig command
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 50610
;pi-hole.net. IN A
pi-hole.net. 295 IN A 3.18.136.52
;; WHEN: Sat May 06 13:24:02 PDT 2023
;; MSG SIZE rcvd: 56
jfb
May 6, 2023, 8:27pm
6
That is the correct reply for that dig command. Problem solved?
From the looks of it yes. What was the issue?
jfb
May 6, 2023, 8:31pm
8
duhipu.ugofin:
What was the issue?
Your OS installed a forwarding configuration, which changed unbound from a recursive resolver (our default setup per our guide) to a forwarding resolver.
Deleting the forwarding configuration and disabling the mechanism that installed that configuration returns unbound to the recursive configuration.
That's weird as I'm using raspberry pi's os 64 bit (fresh install)
jfb
May 6, 2023, 8:34pm
10
That may not be as weird as you think. This is a problem with the Bullseye version of Debian/Raspbian.
