Hallo Forum,
ich habe mir auf meinen Raspberry nun unbound installiert.
Die Config sieht wie folgt aus
server:
interface: 127.0.0.1
port: 5335
do-ip6: no
do-ip4: yes
do-udp: yes
do-tcp: yes
# Set number of threads to use
num-threads: 4
# Hide DNS Server info
hide-identity: yes
hide-version: yes
# Limit DNS Fraud and use DNSSEC
harden-glue: yes
harden-dnssec-stripped: yes
harden-referral-path: yes
use-caps-for-id: yes
harden-algo-downgrade: no
qname-minimisation: yes
aggressive-nsec: yes
rrset-roundrobin: yes
# If DNSSEC isnt working uncomment the following line
# auto-trust-anchor-file: "/var/lib/unbound/root.key"
# Minimum lifetime of cache entries in seconds
cache-min-ttl: 300
# Configure TTL of Cache
cache-max-ttl: 14400
# Optimizations
msg-cache-slabs: 8
rrset-cache-slabs: 8
infra-cache-slabs: 8
key-cache-slabs: 8
serve-expired: yes
serve-expired-ttl: 3600
edns-buffer-size: 1232
prefetch: yes
prefetch-key: yes
target-fetch-policy: "3 2 1 1 1"
unwanted-reply-threshold: 10000000
# Set cache size
rrset-cache-size: 256m
msg-cache-size: 128m
# increase buffer size so that no messages are lost in traffic spikes
so-rcvbuf: 1m
private-address: 10.0.0.0/8
private-address: fd00::/8
private-address: fe80::/10
Im letzten Block "private-address" bin ich mir nicht ganz Sicher. Müssen die Adressen geändert werden oder beliben die wie sie sind?
Danke im Voraus!
