Unbound keep getting SERVFAIL
I tried everything, nothing really help. Also I'm newbie.
dig pi-hole.net @ 127.0.0.1 -p 5335
<<>> DiG 9.16.27-Raspbian <<>> pi-hole.net @ 127.0.0.1 -p 5335
global options: +cmd
Got answer:
->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 48133
flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1
OPT PSEUDOSECTION:
EDNS: version: 0, flags:; udp: 1472
 QUESTION SECTION:
pi-hole.net.                   IN      A
 Query time: 0 msec
SERVER: 127.0.0.1#5335(127.0.0.1)
WHEN: Sat Apr 09 23:41:58 IDT 2022
MSG SIZE  rcvd: 40
unbound-checkconf:
no errors in /etc/unbound/unbound.conf
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:forward-zone:
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:  name: "."
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:  forward-addr: 2a00:a040:0:200::1
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:  forward-addr: 2001:4860:4860::8888
/etc/unbound/unbound.conf.d/pi-hole.conf:    edns-buffer-size: 1472
unbound.service - Unbound DNS server
     Active: active (running) since Sat 2022-04-09 23:15:13 IDT; 21min ago
       Docs: man:unbound(8)
    Process: 26687 ExecStartPre=/usr/lib/unbound/package-helper chroot_setup (code=exited, status=0/SUCCESS)
    Process: 26690 ExecStartPre=/usr/lib/unbound/package-helper root_trust_anchor_update (code=exited, status=0/SUCCESS)
   Main PID: 26693 (unbound)
      Tasks: 1 (limit: 3720)
        CPU: 147ms
     CGroup: /system.slice/unbound.service
             └─26693 /usr/sbin/unbound -d -p
Apr 09 23:15:13 raspberrypi systemd[1]: Starting Unbound DNS server...
Apr 09 23:15:13 raspberrypi unbound[26693]: [26693:0] info: start of service (unbound 1.13.1).
Apr 09 23:15:13 raspberrypi systemd[1]: Started Unbound DNS server.
[(https://tricorder.pi-hole.net/Anpub8Ld/)]
Hope I did right and thanks.
  1. Edit file /etc/resolvconf.conf and comment out the last line which should read:
unbound_conf=/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf
  1. Delete the unwanted unbound configuration file:
sudo rm /etc/unbound/unbound.conf.d/resolvconf_resolvers.conf
  1. Restart unbound:
sudo service unbound restart
