Running Raspbian on a RPi 3. Tried to install Unbound DNS.
No issues when following the official installation guide, but after changing the upstream dns server to 127.0.0.1#5335 no pages would load.
*** [ INITIALIZING ]
[i] 2022-10-03:22:55:33 debug log has been initialized.
[i] System has been running for 62 days, 0 hours, 17 minutes
[i] Core: v5.12.2 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Remotes: origin https://github.com/pi-hole/pi-hole.git (fetch)
origin https://github.com/pi-hole/pi-hole.git (push)
[i] Branch: master
[i] Commit: v5.12.2-0-gd88629e
[i] Web: v5.12 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Remotes: origin https://github.com/pi-hole/AdminLTE.git (fetch)
origin https://github.com/pi-hole/AdminLTE.git (push)
[i] Branch: master
[i] Commit: v5.12-0-g6c320a4
[β] FTL: v5.18.1
[i] Branch: master
[i] Commit: 4c8abe6
[i] 1.4.53
[i] 7.3.31
[i] dig return code: 0
[i] dig response: "Raspbian=10,11 Ubuntu=20,22 Debian=10,11 Fedora=34 CentOS=8 Rocky=8"
[β] Distro: Raspbian
[β] Version: 10
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: FirewallD
[i] Firewalld service inactive
*** [ DIAGNOSING ]: Processor
[β] armv7l
*** [ DIAGNOSING ]: Disk usage
Filesystem Size Used Avail Use% Mounted on
/dev/root 15G 1.8G 12G 13% /
devtmpfs 776M 0 776M 0% /dev
tmpfs 937M 1.6M 935M 1% /dev/shm
tmpfs 937M 97M 840M 11% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 937M 0 937M 0% /sys/fs/cgroup
/dev/mmcblk0p1 253M 49M 204M 20% /boot
tmpfs 188M 0 188M 0% /run/user/999
tmpfs 188M 0 188M 0% /run/user/1000
*** [ DIAGNOSING ]: Network interfaces and addresses
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether dc:a6:32:b3:a7:e4 brd ff:ff:ff:ff:ff:ff
inet 192.168.8.238/24 brd 192.168.8.255 scope global noprefixroute eth0
inet6 fe80::bbc2:ac43:432b:c481/64 scope link
3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether dc:a6:32:b3:a7:e5 brd ff:ff:ff:ff:ff:ff
*** [ DIAGNOSING ]: Network routing table
default via 192.168.8.1 dev eth0 src 192.168.8.238 metric 202
192.168.8.0/24 dev eth0 proto dhcp scope link src 192.168.8.238 metric 202
[β] IPv4 address(es) bound to the eth0 interface:
192.168.8.238/24
[β] IPv6 address(es) bound to the eth0 interface:
[i] Default IPv4 gateway: 192.168.8.1
* Pinging 192.168.8.1...
[β] Gateway responded.
[β] udp:0.0.0.0:53 is in use by pihole-FTL
udp:0.0.0.0:68 is in use by dhcpcd
udp:0.0.0.0:59028 is in use by avahi-daemon
udp:127.0.0.1:5335 is in use by unbound
udp:0.0.0.0:5353 is in use by avahi-daemon
[β] udp:*:53 is in use by pihole-FTL
udp:*:40097 is in use by avahi-daemon
udp:*:5353 is in use by avahi-daemon
[β] tcp:0.0.0.0:80 is in use by lighttpd
[β] tcp:0.0.0.0:53 is in use by pihole-FTL
tcp:0.0.0.0:22 is in use by sshd
tcp:127.0.0.1:5335 is in use by unbound
[β] tcp:127.0.0.1:4711 is in use by pihole-FTL
[β] tcp:[::]:80 is in use by lighttpd
[β] tcp:[::]:53 is in use by pihole-FTL
tcp:[::]:22 is in use by sshd
[β] tcp:[::1]:4711 is in use by pihole-FTL
[β] bpeml.mlb.com is 0.0.0.0 on lo (127.0.0.1)
[β] bpeml.mlb.com is 0.0.0.0 on eth0 (192.168.8.238)
[β] doubleclick.com is 216.58.212.206 via a remote, public DNS server (8.8.8.8)
[β] search.reco.ns.machinens-service.net.zooplus.it is :: on lo (::1)
[β] search.reco.ns.machinens-service.net.zooplus.it is :: on eth0 (fe80::bbc2:ac43:432b:c481)
[β] Failed to resolve doubleclick.com via a remote, public DNS server (2001:4860:4860::8888)
Timeout: 10 seconds
WARN: Could not sendto() in send_dhcp_discover() (/__w/FTL/FTL/src/dhcp-discover.c:233): Network is unreachable
* Received 300 bytes from eth0:192.168.8.1
Offered IP address: 192.168.8.239
Server IP address: 192.168.8.1
Relay-agent IP address: N/A
BOOTP server: (empty)
BOOTP file: (empty)
DHCP options:
Message type: DHCPOFFER (2)
server-identifier: 192.168.8.1
lease-time: 43200 ( 12h )
renewal-time: 21600 ( 6h )
rebinding-time: 37800 ( 10h 30m )
netmask: 255.255.255.0
broadcast: 192.168.8.255
router: 192.168.8.1
dns-server: 192.168.8.1
domain-name: "lan"
--- end of options ---
DHCP packets received on interface wlan0: 0
[β] lighttpd daemon is active
[β] pihole-FTL daemon is active
*** [ DIAGNOSING ]: Pi-hole-FTL full status
β pihole-FTL.service - LSB: pihole-FTL daemon
Active: active (exited) since Mon 2022-10-03 22:45:14 BST; 10min ago
Process: 21116 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
Oct 03 22:45:14 raspberrypi systemd[1]: Starting LSB: pihole-FTL daemon...
Oct 03 22:45:14 raspberrypi pihole-FTL[21116]: Not running
Oct 03 22:45:14 raspberrypi su[21138]: (to pihole) root on none
Oct 03 22:45:14 raspberrypi su[21138]: pam_unix(su:session): session opened for user pihole by (uid=0)
Oct 03 22:45:14 raspberrypi pihole-FTL[21116]: FTL started!
Oct 03 22:45:14 raspberrypi su[21138]: pam_unix(su:session): session closed for user pihole
Oct 03 22:45:14 raspberrypi systemd[1]: Started LSB: pihole-FTL daemon.
BLOCKING_ENABLED=true
IPV4_ADDRESS=192.168.8.238/24
IPV6_ADDRESS=
DNSSEC=false
REV_SERVER=false
PIHOLE_INTERFACE=eth0
QUERY_LOGGING=false
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
CACHE_SIZE=10000
DNS_FQDN_REQUIRED=true
DNS_BOGUS_PRIV=true
DNSMASQ_LISTENING=local
PIHOLE_DNS_1=9.9.9.10
PIHOLE_DNS_2=149.112.112.10
PIHOLE_DNS_3=127.0.0.1#5335
*** [ DIAGNOSING ]: Dashboard headers
[β] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
*** [ DIAGNOSING ]: Pi-hole FTL Query Database
-rw-rw-r-- 1 pihole pihole 125M Oct 3 22:55 /etc/pihole/pihole-FTL.db
*** [ DIAGNOSING ]: Gravity Database
-rw-rw-r-- 1 pihole pihole 14M Oct 3 22:44 /etc/pihole/gravity.db
*** [ DIAGNOSING ]: Info table
property value
version 15
updated 1664833471
gravity_count 177551
Last gravity run finished at: Mon Oct 3 22:44:31 BST 2022
----- First 10 Gravity Domains -----
localhost.localdomain
eu1.clevertap-prod.com
wizhumpgyros.com
coccyxwickimp.com
webmail-who-int.000webhostapp.com
010sec.com
01mspmd5yalky8.com
0byv9mgbn0.com
ns6.0pendns.org
dns.0pengl.com
*** [ DIAGNOSING ]: Groups
id enabled name date_added date_modified description
0 1 Default 2021-08-25 00:56:47 2021-08-25 00:56:47 The default group
id type enabled group_ids domain date_added date_modified comment
1 1 1 0 clicktale.net 2021-08-25 01:39:11 2021-08-25 01:39:11
2 1 1 0 www.clicktale.net 2021-08-25 01:39:11 2021-08-25 01:39:11
3 1 1 0 conductor.clicktale.net 2021-08-25 01:39:11 2021-08-25 01:39:11
4 1 1 0 www.conductor.clicktale.net 2021-08-25 01:39:11 2021-08-25 01:39:11
5 1 1 0 ing-district.clicktale.net 2021-08-25 01:39:11 2021-08-25 01:39:11
6 1 1 0 www.ing-district.clicktale.net 2021-08-25 01:39:11 2021-08-25 01:39:11
7 1 1 0 cdnssl.clicktale.net 2021-08-25 01:39:11 2021-08-25 01:39:11
8 1 1 0 www.cdnssl.clicktale.net 2021-08-25 01:39:11 2021-08-25 01:39:11
9 1 1 0 cdn.clicktale.net 2021-08-25 01:39:11 2021-08-25 01:39:11
10 1 1 0 www.cdn.clicktale.net 2021-08-25 01:39:11 2021-08-25 01:39:11
11 1 1 0 static.hotjar.com 2021-08-25 01:39:11 2021-08-25 01:39:11
12 1 1 0 www.static.hotjar.com 2021-08-25 01:39:11 2021-08-25 01:39:11
13 1 1 0 script.hotjar.com 2021-08-25 01:39:11 2021-08-25 01:39:11
14 1 1 0 www.script.hotjar.com 2021-08-25 01:39:11 2021-08-25 01:39:11
15 1 1 0 mc.yandex.ru 2021-08-25 01:39:11 2021-08-25 01:39:11
16 1 1 0 www.mc.yandex.ru 2021-08-25 01:39:11 2021-08-25 01:39:11
17 1 1 0 cdn.decibelinsight.net 2021-08-25 01:39:11 2021-08-25 01:39:11
18 1 1 0 www.cdn.decibelinsight.net 2021-08-25 01:39:11 2021-08-25 01:39:11
19 1 1 0 ws.sessioncam.com 2021-08-25 01:39:11 2021-08-25 01:39:11
20 1 1 0 www.ws.sessioncam.com 2021-08-25 01:39:11 2021-08-25 01:39:11
21 1 1 0 d2oh4tlt9mrke9.cloudfront.net 2021-08-25 01:39:11 2021-08-25 01:39:11
22 1 1 0 www.d2oh4tlt9mrke9.cloudfront.net 2021-08-25 01:39:11 2021-08-25 01:39:11
23 1 1 0 api.iperceptions.com 2021-08-25 01:39:11 2021-08-25 01:39:11
24 1 1 0 www.api.iperceptions.com 2021-08-25 01:39:11 2021-08-25 01:39:11
25 1 1 0 bskyb.demdex.net 2021-08-25 01:39:11 2021-08-25 01:39:11
26 1 1 0 www.bskyb.demdex.net 2021-08-25 01:39:11 2021-08-25 01:39:11
27 1 1 0 dpm.demdex.net 2021-08-25 01:39:11 2021-08-25 01:39:11
28 1 1 0 www.dpm.demdex.net 2021-08-25 01:39:11 2021-08-25 01:39:11
29 1 1 0 col.eum-appdynamics.com 2021-08-25 01:39:11 2021-08-25 01:39:11
30 1 1 0 www.col.eum-appdynamics.com 2021-08-25 01:39:11 2021-08-25 01:39:11
31 1 1 0 cdn.mouseflow.com 2021-08-25 01:39:11 2021-08-25 01:39:11
32 1 1 0 www.cdn.mouseflow.com 2021-08-25 01:39:11 2021-08-25 01:39:11
33 1 1 0 cdn.inspectlet.com 2021-08-25 01:39:11 2021-08-25 01:39:11
34 1 1 0 www.cdn.inspectlet.com 2021-08-25 01:39:11 2021-08-25 01:39:11
35 1 1 0 hn.inspectlet.com 2021-08-25 01:39:11 2021-08-25 01:39:11
36 1 1 0 www.hn.inspectlet.com 2021-08-25 01:39:11 2021-08-25 01:39:11
37 1 1 0 wu-app.quantummetric.com 2021-08-25 01:39:11 2021-08-25 01:39:11
38 1 1 0 www.wu-app.quantummetric.com 2021-08-25 01:39:11 2021-08-25 01:39:11
39 1 1 0 cdn.quantummetric.com 2021-08-25 01:39:11 2021-08-25 01:39:11
40 1 1 0 www.cdn.quantummetric.com 2021-08-25 01:39:11 2021-08-25 01:39:11
41 1 1 0 neimans-app.quantummetric.com 2021-08-25 01:39:11 2021-08-25 01:39:11
42 1 1 0 www.neimans-app.quantummetric.com 2021-08-25 01:39:11 2021-08-25 01:39:11
43 1 1 0 frontier-app.quantummetric.com 2021-08-25 01:39:11 2021-08-25 01:39:11
44 1 1 0 www.frontier-app.quantummetric.com 2021-08-25 01:39:11 2021-08-25 01:39:11
45 1 1 0 d10lpsik1i8c69.cloudfront.net 2021-08-25 01:39:11 2021-08-25 01:39:11
46 1 1 0 www.d10lpsik1i8c69.cloudfront.net 2021-08-25 01:39:11 2021-08-25 01:39:11
47 1 1 0 rs.fullstory.com 2021-08-25 01:39:11 2021-08-25 01:39:11
48 1 1 0 www.rs.fullstory.com 2021-08-25 01:39:11 2021-08-25 01:39:11
49 1 1 0 bizographics.com 2021-08-25 01:39:11 2021-08-25 01:39:11
50 1 1 0 www.bizographics.com 2021-08-25 01:39:11 2021-08-25 01:39:11
51 1 1 0 rec.smartlook.com 2021-08-25 01:39:11 2021-08-25 01:39:11
52 1 1 0 www.rec.smartlook.com 2021-08-25 01:39:11 2021-08-25 01:39:11
53 1 1 0 sb.scorecardresearch.com 2021-08-25 01:39:11 2021-08-25 01:39:11
54 1 1 0 www.sb.scorecardresearch.com 2021-08-25 01:39:11 2021-08-25 01:39:11
55 1 1 0 cdn.userreplay.net 2021-08-25 01:39:11 2021-08-25 01:39:11
56 1 1 0 www.cdn.userreplay.net 2021-08-25 01:39:11 2021-08-25 01:39:11
57 1 1 0 onaudience.com 2021-08-25 01:39:11 2021-08-25 01:39:11
58 1 1 0 www.onaudience.com 2021-08-25 01:39:11 2021-08-25 01:39:11
59 1 1 0 pixel.onaudience.com 2021-08-25 01:39:11 2021-08-25 01:39:11
60 1 1 0 www.pixel.onaudience.com 2021-08-25 01:39:11 2021-08-25 01:39:11
64 1 1 0 www.instagram.com 2021-11-02 21:52:24 2021-11-02 21:52:53
65 1 1 0 instagram.com 2021-11-02 21:52:30 2021-11-02 21:52:30 Added from Query Log
68 0 1 0 googleads.g.doubleclick.net 2021-12-24 13:15:45 2021-12-24 13:15:45 Added from Query Log
69 0 1 0 app.adjust.world 2022-01-19 19:03:24 2022-01-19 19:03:24 Added from Query Log
70 0 1 0 sdk.split.io 2022-01-19 19:03:27 2022-01-19 19:03:27 Added from Query Log
71 0 1 0 cdn.segment.com 2022-01-19 19:04:10 2022-01-19 19:04:10 Added from Query Log
*** [ DIAGNOSING ]: Clients
*** [ DIAGNOSING ]: Adlists
id enabled group_ids address date_added date_modified comment
1 1 0 https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts 2021-08-25 00:56:47 2021-08-25 00:56:47 Migrated from /etc/pihole/adlists.list
2 1 0 https://raw.githubusercontent.com/anudeepND/blacklist/master/facebook.txt 2021-08-25 01:32:46 2021-08-25 01:32:46
3 1 0 https://adaway.org/hosts.txt 2021-08-25 01:33:33 2021-08-25 01:33:33
4 1 0 https://v.firebog.net/hosts/Easyprivacy.txt 2021-08-25 01:33:48 2021-08-25 01:33:48
5 1 0 https://raw.githubusercontent.com/Perflyst/PiHoleBlocklist/master/AmazonFireTV.txt 2021-08-25 01:34:04 2021-08-25 01:34:04
6 1 0 https://raw.githubusercontent.com/kboghdady/youTube_ads_4_pi-hole/master/youtubelist.txt 2022-05-13 14:19:29 2022-05-13 14:19:29
-rw-r--r-- 1 root root 0 Aug 25 2021 /etc/pihole/custom.list
-rw-r--r-- 1 root root 65 Oct 3 22:44 /etc/pihole/local.list
-rw-r--r-- 1 root root 241 Oct 3 22:44 /etc/pihole/logrotate
/var/log/pihole/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole/FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-rw-r-- 1 pihole root 34 Oct 3 22:45 /etc/pihole/pihole-FTL.conf
RATE_LIMIT=1000/60
PRIVACYLEVEL=0
-rw-r--r-- 1 root root 1.4K Oct 3 22:45 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-facility=/var/log/pihole/pihole.log
log-async
server=9.9.9.10
server=149.112.112.10
server=127.0.0.1#5335
domain-needed
expand-hosts
bogus-priv
local-service
-rw-r--r-- 1 root root 2.2K Oct 3 22:44 /etc/dnsmasq.d/06-rfc6761.conf
server=/test/
server=/localhost/
server=/invalid/
server=/bind/
server=/onion/
-rw-r--r-- 1 root root 0 Mar 9 2022 /etc/lighttpd/external.conf
-rw-r--r-- 1 root root 5.6K Oct 3 22:44 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "/pihole/index.php"
server.errorlog = "/var/log/lighttpd/error-pihole.log"
server.pid-file = "/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
accesslog.filename = "/var/log/lighttpd/access-pihole.log"
server.stream-response-body = 1
mimetype.assign = (
".ico" => "image/x-icon",
".jpeg" => "image/jpeg",
".jpg" => "image/jpeg",
".png" => "image/png",
".svg" => "image/svg+xml",
".html" => "text/html; charset=utf-8",
".js" => "text/javascript; charset=utf-8",
".json" => "application/json; charset=utf-8",
".map" => "application/json; charset=utf-8",
".txt" => "text/plain; charset=utf-8",
".eot" => "application/vnd.ms-fontobject",
".otf" => "font/otf",
".ttc" => "font/collection",
".ttf" => "font/ttf",
".woff" => "font/woff",
".woff2" => "font/woff2"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY",
"X-XSS-Protection" => "1; mode=block",
"X-Content-Type-Options" => "nosniff",
"Content-Security-Policy" => "default-src 'self' 'unsafe-inline';",
"X-Permitted-Cross-Domain-Policies" => "none",
"Referrer-Policy" => "same-origin"
url.access-deny = ("")
$HTTP["url"] =~ "/(teleporter|api_token)\.php$" {
$HTTP["referer"] =~ "/admin/settings\.php" {
setenv.add-response-header = ( "X-Frame-Options" => "SAMEORIGIN" )
expire.url = ( "" => "access plus 0 seconds" )
-rw-r--r-- 1 root root 1.8K Oct 3 22:44 /etc/cron.d/pihole
51 3 * * 7 root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updateGravity >/var/log/pihole/pihole_updateGravity.log || cat /var/log/pihole/pihole_updateGravity.log
00 00 * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole flush once quiet
@reboot root /usr/sbin/logrotate --state /var/lib/logrotate/pihole /etc/pihole/logrotate
*/10 * * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker local
15 14 * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 71 Oct 3 22:44 /var/log/lighttpd/error-pihole.log
-----head of error-pihole.log------
2022-10-03 22:44:18: (server.c.1464) server started (lighttpd/1.4.53)
-----tail of error-pihole.log------
*** [ DIAGNOSING ]: contents of /var/log/pihole
-rw-r--r-- 1 pihole pihole 33K Oct 3 22:50 /var/log/pihole/FTL.log
-----head of FTL.log------
[2022-10-03 01:00:00.042 608/T612] Notice: Database size is 130.07 MB, deleted 4 rows
[2022-10-03 02:00:00.046 608/T612] Notice: Database size is 130.07 MB, deleted 4 rows
[2022-10-03 03:00:00.042 608/T612] Notice: Database size is 130.07 MB, deleted 4 rows
[2022-10-03 04:00:00.109 608/T612] Notice: Database size is 130.07 MB, deleted 4 rows
[2022-10-03 05:00:00.074 608/T612] Notice: Database size is 130.07 MB, deleted 4 rows
[2022-10-03 06:00:00.133 608/T612] Notice: Database size is 130.07 MB, deleted 4 rows
[2022-10-03 07:00:00.111 608/T612] Notice: Database size is 130.07 MB, deleted 4 rows
[2022-10-03 08:00:00.119 608/T612] Notice: Database size is 130.07 MB, deleted 4 rows
[2022-10-03 09:00:00.106 608/T612] Notice: Database size is 130.07 MB, deleted 4 rows
[2022-10-03 10:00:00.037 608/T612] Notice: Database size is 130.07 MB, deleted 4 rows
[2022-10-03 11:00:00.100 608/T612] Notice: Database size is 130.07 MB, deleted 90 rows
[2022-10-03 12:00:00.112 608/T612] Notice: Database size is 130.07 MB, deleted 8 rows
[2022-10-03 12:36:11.184 608M] Resizing "FTL-dns-cache" from 221184 to (14080 * 16) == 225280 (/dev/shm: 2.1MB used, 981.6MB total, FTL uses 2.1MB)
[2022-10-03 12:50:34.192 608M] Resizing "FTL-strings" from 286720 to (327680 * 1) == 327680 (/dev/shm: 2.1MB used, 981.6MB total, FTL uses 2.1MB)
[2022-10-03 13:00:00.254 608/T612] Notice: Database size is 130.07 MB, deleted 8 rows
[2022-10-03 14:00:00.252 608/T612] Notice: Database size is 130.07 MB, deleted 4 rows
[2022-10-03 15:00:00.114 608/T612] Notice: Database size is 130.07 MB, deleted 4 rows
[2022-10-03 16:00:00.072 608/T612] Notice: Database size is 130.07 MB, deleted 4 rows
[2022-10-03 16:48:44.368 608M] Resizing "FTL-dns-cache" from 225280 to (14336 * 16) == 229376 (/dev/shm: 2.2MB used, 981.6MB total, FTL uses 2.2MB)
[2022-10-03 17:00:00.370 608/T612] Notice: Database size is 130.07 MB, deleted 295 rows
[2022-10-03 17:59:00.150 608/T612] Notice: Database size is 130.07 MB, deleted 7 rows
[2022-10-03 18:32:44.292 608M] Resizing "FTL-dns-cache" from 229376 to (14592 * 16) == 233472 (/dev/shm: 2.2MB used, 981.6MB total, FTL uses 2.2MB)
[2022-10-03 19:00:00.123 608/T612] Notice: Database size is 130.07 MB, deleted 240 rows
[2022-10-03 20:00:00.017 608/T612] Notice: Database size is 130.07 MB, deleted 12 rows
[2022-10-03 21:00:00.115 608/T612] Notice: Database size is 130.07 MB, deleted 8 rows
[2022-10-03 22:00:00.091 608/T612] Notice: Database size is 130.07 MB, deleted 8 rows
[2022-10-03 22:27:59.252 608M] Shutting down...
[2022-10-03 22:27:59.524 608M] Finished final database update (stored 4 queries)
[2022-10-03 22:27:59.524 608M] Waiting for threads to join
[2022-10-03 22:27:59.524 608M] Thread telnet-IPv4 (0) is idle, terminating it.
[2022-10-03 22:27:59.524 608M] Thread telnet-IPv6 (1) is idle, terminating it.
[2022-10-03 22:27:59.525 608M] Thread telnet-socket (2) is idle, terminating it.
[2022-10-03 22:27:59.525 608M] Thread database (3) is idle, terminating it.
[2022-10-03 22:27:59.526 608M] Thread housekeeper (4) is idle, terminating it.
[2022-10-03 22:27:59.526 608M] Thread DNS client (5) is idle, terminating it.
