I installed unbound on my pi.
All runs great, but I recognize, that domain
deutsche-glasfaser.de
doesn´ resolve an ip?!
On ssh I tried:
dig deutsche-glasfaser.de @127.0.0.1 -p5335
; <<>> DiG 9.16.1-Ubuntu <<>> deutsche-glasfaser.de @127.0.0.1 -p5335
On Google-DNS it works great
dig deutsche-glasfaser.de @8.8.8.8
; <<>> DiG 9.16.1-Ubuntu <<>> deutsche-glasfaser.de @8.8.8.8
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 40189
;deutsche-glasfaser.de. IN A
deutsche-glasfaser.de. 21600 IN A 185.22.44.179
;; Query time: 36 msec
;; SERVER: 8.8.8.8#53(8.8.8.8)
;; WHEN: Sun Mar 13 09:41:01 CET 2022
;; MSG SIZE rcvd: 66
Other Domains on unbound works also great:
dig heise.de @127.0.0.1 -p5335
; <<>> DiG 9.16.1-Ubuntu <<>> heise.de @127.0.0.1 -p5335
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 33145
;heise.de. IN A
heise.de. 86400 IN A 193.99.144.80
;; Query time: 40 msec
;; WHEN: Sun Mar 13 09:41:28 CET 2022
;; MSG SIZE rcvd: 53
So, where is the Problem?
Greets
Byte
Thanks, but this didnt help me much.
wd9895
March 13, 2022, 11:09am
4
If the rest of your daily domains works I woul try to disable the blocklists step by step and find out if this specific deny is caused here.
; <<>> DiG 9.16.22-Raspbian <<>> deutsche-glasfaser.de @127.0.0.1 -p5335
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 26587
deutsche-glasfaser.de. 81626 IN A 185.22.44.179
;; Query time: 0 msec
;; WHEN: Sun Mar 13 12:05:10 CET 2022
there is no blocklist! I´ve disabled pi-hole.
Greets
Although I think there will be no difference, there should be a space between -p
and the port number.
This doesn't only resolve to an IP, but means unbound did not receive the query at all.
What OS are you using?
jfb
March 14, 2022, 1:05am
7
Since this DNS query was routed directly to unbound (and not via Pi-hole), no blocking from Pi-hole would be in effect.
jfb
March 14, 2022, 1:08am
8
You will need to look under the hood with unbound to see why this specific query has failed. In your unbound configuration file that you installed using the Pi-hole unbound guide, change the verbosity to 5. Restart unbound, repeat the query, then look at the details in the unbound log.
Don't forget to reduce the verbosity at the end of troubleshooting, or the unbound log will grow quite quickly.
system
Closed
April 4, 2022, 1:08am
9
