$ apt show openresolv
Description: management framework for resolv.conf
Allows multiple daemons to manage resolv.conf and configures
local resolvers such as dnsmasq and unbound.
This package may require some manual configuration.
Please read resolvconf(8) and resolvconf.conf(5) for detailed instructions.
But apparently the latest Pi-OS Bookworm doesnt and the task previously performed by openresolv has been taken over by network-manager:
$ apt show network-manager
Description: network management framework (daemon and userspace tools)
NetworkManager is a system network service that manages your network devices
and connections, attempting to keep active network connectivity when
available. It manages ethernet, Wi-Fi, mobile broadband (WWAN), and PPPoE
devices, and provides VPN integration with a variety of different VPN
services.
$ man NetworkManager.conf
dns
Set the DNS processing mode.
If the key is unspecified, default is used, unless
/etc/resolv.conf is a symlink to
/run/systemd/resolve/stub-resolv.conf,
/run/systemd/resolve/resolv.conf, /lib/systemd/resolv.conf or
/usr/lib/systemd/resolv.conf. In that case, systemd-resolved
is chosen automatically.
default: NetworkManager will update /etc/resolv.conf to
reflect the nameservers provided by currently active
connections. The rc-manager setting (below) controls how this
is done.
rc-manager
Set the resolv.conf management mode. This option is about how
NetworkManager writes to /etc/resolv.conf, if at all.
Check out above man page for more details.
I cant confirm bc I dont have Pi-OS Bookworm installed yet on my Pi's.
But I do have a Debian Bookworm VM for tinkering thats running Network Manager + Pi-hole + Unbound and that one works just fine without any openresolv installed.
In the tuto, there are :
sudo sed -Ei 's/^unbound_conf=/#unbound_conf=/' /etc/resolvconf.conf
sudo rm /etc/unbound/unbound.conf.d/resolvconf_resolvers.conf
I do not have to replace by anything ?
After restarting and asking the status of the service, I have that :
Loaded: loaded (/lib/systemd/system/unbound.service; enabled; preset: enabled)
Active: active (running) since Sat 2025-05-17 21:45:56 CEST; 5s ago
Docs: man:unbound(8)
Process: 13333 ExecStartPre=/usr/libexec/unbound-helper chroot_setup (code=exited, status=0/SUCCESS)
Process: 13335 ExecStartPre=/usr/libexec/unbound-helper root_trust_anchor_update (code=exited, status=0/SUCCESS)
Main PID: 13338 (unbound)
Tasks: 1 (limit: 760)
CPU: 219ms
CGroup: /system.slice/unbound.service
└─13338 /usr/sbin/unbound -d -p
mai 17 21:45:56 pi-hole2 systemd[1]: Starting unbound.service - Unbound DNS server...
mai 17 21:45:56 pi-hole2 unbound[13338]: [13338:0] warning: subnetcache: prefetch is set but not working for data originating from the subnet module cache.
mai 17 21:45:56 pi-hole2 unbound[13338]: [13338:0] info: start of service (unbound 1.17.1).
mai 17 21:45:56 pi-hole2 systemd[1]: Started unbound.service - Unbound DNS server.
And serves below purpose wich is not desired in our use case so we disable it in the guide:
$ systemctl cat unbound-resolvconf.service
# /lib/systemd/system/unbound-resolvconf.service
# This is a helper unit to register local unbound resolver daemon in
# resolv.conf. This is done asyncronously in order not to slow down
# the main unbound service startup, since this will trigger resolvconf
# reload of other services which might be a lengthly procedure.
# See #826241 for the origins of this service.
# Can this whole thing be done using ExecStartPost= in unbound.service?
ExecStart=/usr/libexec/unbound-helper resolvconf_start
But still have to cleanup that generated file afterwards.
