unbound.conf and pi-hole.conf
I have just installed Pi-hole on a Debian minimal server, along with Unbound DNS resolver. And I think it's working fine.
First I installed Unbound, using this nlnetlabs page, and then I followed this Pi-hole guide.
My questions are regarding /etc/unbound/unbound.conf and /etc/unbound/unbound.conf.d/pi-hole.conf .
(1) Are both of these config files, unbound.conf and pi-hole.conf, should be configured exactly same?
(2) I have added few things on my own in pi-hole.conf, that I found in this Unbound manpage, though commented out some of them, as I wasn't sure whether they should be there. Could someone knowledgeable comment on that please.
Many thanks in advance, any help is greatly appreciated. -Jags
my /etc/unbound/unbound.conf is:
server:
    interface: 0.0.0.0
    interface: ::0
    access-control: 192.168.0.0/16 allow
    access-control: ::1 allow
    verbosity: 1
my /etc/unbound/unbound.conf.d/pi-hole.conf is:
server:
    interface: 0.0.0.0
    interface: ::0
    # access-control: 0.0.0.0/0 allow
    private-address: 10.0.0.0/8
    private-address: fd00::/8
    private-address: fe80::/10
    # Minimum lifetime of cache entries in seconds.  Default is 0.
    cache-min-ttl: 60
    # Maximum lifetime of cached entries. Default is 86400 seconds (1  day).
    cache-max-ttl: 259200
    port: 5353
    do-ip4: yes
    do-ip6: no
    do-udp: yes
    do-tcp: yes
    do-daemonize: no
    # default is to use syslog, which will log to /var/log/messages.
    use-syslog: no
    # to log elsewhere, set 'use-syslog' to 'no', and set the log file location below:
    logfile: "/var/log/unbound/unbound.log"
    log-time-ascii: yes
    verbosity: 2
    # This is set to 'no' above already. May be set to yes if you have IPv6 connectivity:
    # do-ip6: no
    root-hints: "/var/lib/unbound/root.hints"
    # Trust glue only if it is within the servers authority
    harden-glue: yes
    harden-dnssec-stripped: yes
    # enable to not answer id.server and hostname.bind queries.
    hide-identity: yes
    # enable to not answer version.server and version.bind queries.
    hide-version: yes
    use-caps-for-id: no
    # Suggested by the unbound man page to reduce fragmentation reassembly problems
    edns-buffer-size: 1472
    prefetch: yes
    # One thread should be sufficient, can be increased on beefy machines. In reality for most users running on small networks or on a single machine it should be unnecessary to seek performance enhancement by increasing num-threads above 1.
    num-threads: 2
    so-rcvbuf: 10m
    val-clean-additional: yes
    val-sig-skew-min: 3600
    val-sig-skew-max: 86400
    val-bogus-ttl: 60
    val-log-level: 2
    # python:
    # remote-control:
    # control-enable: no
    # chroot: "/var/unbound"
    # username: "unbound"
    # directory: "/var/unbound"
    # pidfile: "/var/run/unbound.pid"
    # tcp-upstream: no
    # cache-max-negative-ttl: 0
    # neg-cache-size: 0
    # unwanted-reply-threshold: 10000
    # do-not-query-localhost: yes
    # auto-trust-anchor-file: "root.key"
    # log-queries: no
    # log-replies: no
Your unbound settings should be in the pihole.conf file. From memory only (away from home now) the unbound file is a pointer to the extra configuration directory.
