Hi Guys.
I saw another thread here that shows instructions for making it so pi hole doesn't act as a DNS server for a specific device: Unblocking a single devices
I need this so that my NAS uses google DNS servers while all my other devices use pi hole. This will allow me to have my NAS be connected to a VPN on my secondary router at all times while allowing other devices to bypass VPN by using my primary router.
So I added the following to the DNS/DHCP section of my primary Tomato based router under the DNSMASQ area as that thread stated:
dhcp-option=6,192.168.1.4
dhcp-option=tag:googlesdns1,6,8.8.8.8
dhcp-option=tag:googlesdns2,6,8.8.4.4
dhcp-host=00:11:32:XX:XX:XX,set:googlesdns1
The pi hole is my DNS server for all my devices on my primary router as you can see from the first part of the DNSMASQ entry I listed.
But it is not working. The device in question cannot resolve DNS requests so apps on it such as Sonarr will not work. It’s a Synology NAS that uses my secondary VPN router as its gateway. The NAS is the only device using the VPN router as its gateway. I am thinking the NAS using a different gateway then the pi is the reason behind this but thought the instructions in that thread would fix it. Any ideas?
