Web version is not updating for me
Admin panel
something is wrong, I have restarted my vps, and is the same.
I also can't get the update,, I tried
sudo git reset --hard
and
sudo pihole checkout master
@elaur @deathbybandaid were either of you on different branches at some point before updating?
ge204cea is in fact the correct commit to be on, but the version isn't reporting correctly . Try:
cd /var/www/html/admin
sudo git fetch --tags
I keep my main pi on the master branch,,,, the wife doesn't like when the internet is being funny,,,,
remote: Counting objects: 118, done.
remote: Compressing objects: 100% (43/43), done.
remote: Total 118 (delta 82), reused 107 (delta 71), pack-reused 0
Receiving objects: 100% (118/118), 84.33 KiB | 0 bytes/s, done.
Resolving deltas: 100% (82/82), completed with 41 local objects.
From https://github.com/pi-hole/AdminLTE
* [new tag] 1.2.1-bower -> 1.2.1-bower
* [new tag] 1.3.0 -> 1.3.0
* [new tag] 1.3.1 -> 1.3.1
* [new tag] v1.2.1 -> v1.2.1
- [tag update] v3.0.1 -> v3.0.1
Edit: that seems to have done the trick
I tried it on a new install and it seemed to fetch the tag version correctly, but when I updated my home install it did the same as you both described.
That said, mine is always on different branches. My wife is quite forgiving when things go wrong ![]()
I do have a cronjob to run pihole -up every half-hour, so that I should theoretically always be on the newest release.
I don't know if that would make a difference, but it shouldn't
Keen! We don't release that often ![]()
Looks like this issue will be seen across the board, as it seems to be with a pre-existing v.3.0.1 (from the original AdminLTE repo) tag that we deleted the other day.
Can you run a No don't. It wont show that.pihole -up now? Should show version 3.0.1a
I was just about to say that it didn't work lol
I'm a very new user. My install is less than 24 hours ago.
I was prompted with the update in the admin panel. I ran a pihole -up and now I get a Pi-hole Version v3.0.1 Web Interface Version v3.0.1 FTL Version v2.6.
It now asks for a password as advertised. Great job. Thanks!
