Unable to resolve pi-hole dns when connected to VPN
Connect to a VPN server provided by Private Internet Access and use Pi-Hole as a DNS server address
Unable to resolve DNS. Connection is stuck at "Looking up address" [Firefox] or "Resolving Host"
Debug Token: qgx4y9n73o
Additional Info:
I've been using the Pi-Hole successfully on a Raspberry Pi running Raspbian stretch for the past year with no issues, where I would set up each device I manually by setting the DNS server address as the Pi-Hole IP address. After updating to 4.0, I've been unable to use the PI-Hole as my DNS server when I'm connected to a VPN on my Windows computer. This is the only instance of it not working, as I can connect to and use the PI hole as a DNS server for my other devices, as well as on that same Windows computer, as long as I've disconnected from the VPN. Connection with VPN works fine when I let the VPN TAP driver obtain its DNS server address automatically.
I'm using Private Internet Access VPN with the DNS Leak Protection setting disabled (as that was causing issues a few months ago until I disabled it)
Preferred DNS address for both my standard ethernet driver and TAP driver are set to PI-Holes IP address.
What kind of VPN server software are you using?
Normally I use the default client that PIA recommends, but I've also tried using OpenVPN with the configuration files that PIA supplies with no success.
How is your Interface listening behavior set-up under Settings/DNS ?
Normally I use listen only on interface eth0, but I've tried both listen on all interfaces and listen on all interfaces permit all origins without success.
