Unable to get to gov.uk domain when using PiHole & Unbound
Hi, I'm unable to reach gov.uk when using Pihole & Unbound. This has been a recurring problem even when freshly reinstalling both on various systems.
Currently using pihole on a Raspberry Pi Zero however have used it in the past on a Thinkcentre machine and the same issue occurs.
Both pihole and unbound have been setup through the recommended procedure in the Pi-hole installation documentation.
<<>> DiG 9.16.42-Raspbian <<>> gov.uk (at)127.0.0.1 -p 5335
 global options: +cmd
 connection timed out; no servers could be reached
if it helps ^
Many thanks team! :smiley:
Let's take a look at your unbound configuration. Please post the output of the following command from the Pi terminal:
andy@pizero:~ $ sudo grep -v '#\|^$' -R /etc/unbound/unbound.conf*                                                            /etc/unbound/unbound.conf:include-toplevel: "/etc/unbound/unbound.conf.d/*.conf"
/etc/unbound/unbound.conf.d/root-auto-trust-anchor-file.conf:    auto-trust-anch                                              or-file: "/var/lib/unbound/root.key"
/etc/unbound/unbound.conf.d/pi-hole.conf:    edns-buffer-size: 1232
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:forward-zone:
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:  name: "."
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:  forward-addr: 192.168.0.1
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:  forward-addr: 9.9.9.9
Thanks for your reply jfb :smiley:
I would try using Google's 8.8.8.8 instead of Quad 9's 9.9.9.9 upstream DNS server, just to see if that fixes it.
Domains ending in .gov being blocked has been mentioned in the past (e.g. issues with nist.gov · Issue #2708 · pi-hole/pi-hole · GitHub) , both on here and Reddit, and it's usually down to the upstream DNS server treating .gov as malicious.
Specifically, this has been know to happen with cloudflare on 1.1.1.1 in the past. But it stands to reason that whatever their source for "malicious" domains, it's possible Quad9 on 9.9.9.9 are using the same source.
Your unbound is currently configured as a forwarding resolver, not as a recursive resolver. This change was likely made by your operating system.
  1. Edit file /etc/resolvconf.conf and comment out the last line which should then read:
#unbound_conf=/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf
  1. Delete the unwanted unbound configuration file:
sudo rm /etc/unbound/unbound.conf.d/resolvconf_resolvers.conf
  1. Restart unbound:
sudo service unbound restart
Thanks jfb, this seems to have done the trick :smiley:
Hi jfb, looks to not be working again. Can't access domains like gov.uk and twitch.tv all of a sudden. Any help would be appreciated! :slight_smile:
Same here. With me it happened when Virgin Media changed my IP address.
I now have a file /etc/dnsmasq.d/99-my-settings.conf in which I have added:
server=/**.gov.uk/1.0.0.1
server=/*.tv/1.0.0.1
and then restarted dns
(There should be a single asterisk on that first line )
It appears there is a problem routing to the name servers authorative for these domains from Virgin's network. My Pihole now uses 1.0.0.1 to lookup just these domains instead of using unbound.
DNSSEC Debugger - gov.uk tests ok
gov.uk | DNSViz is full of no response errors
dnsviz - GitHub - dnsviz/dnsviz - appears to be a script run from within your browser so indicates your ISP's shortcomings.
Thanks mate, very helpful. I'm also using Virgin Media and have been wondering why Pi-Hole consistantly breaks on my network. :smiley:
are there any extra steps in order to get pi.hole to actually use that 99-my-settings.conf file? do i need to add it to the base config file?
No. I think I just clicked on restart DNS resolver on the settings tab. I had previously created it for some other settings.
yeah thanks Moto, wasn't working at first but it was my mistake. thanks a lot for your help :smiley:
Unbound has a special mode for logging DNSSEC failures. It would be interesting to enable it and try the gov digs again from Virgin Media and see what it reports.
Setup
To enable it, first of all enable Unbound logging to a dedicated log file, as per the "Add logging to unbound" part of the Pi-hole guide. Don't forget to create the log file, set the permissions and do the AppArmor steps, as per the guide.
Then add the special logging mode val-log-level set to 2 ("At 2, not only the query that failed is printed but also the reason why Unbound thought it was wrong and which server sent the faulty data.")
So it looks like this once done:
$ sudo nano /etc/unbound/unbound.conf.d/pi-hole.conf
server:
    logfile: "/var/log/unbound/unbound.log"
    log-time-ascii: yes
    val-log-level: 2
    verbosity: 0
Restart Unbound
Testing
Now try to access the gov sites again, try dig etc. Any failures will be logged with the details. Eg using the test domains to dig, seeing the failures then looking at the log.
$ dig fail03.dnssec.works @127.0.0.1 -p 5335
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 54208
$ dig fail04.dnssec.works @127.0.0.1 -p 5335
; <<>> DiG 9.16.42-Debian <<>> fail04.dnssec.works @127.0.0.1 -p 5335
Log
$ less /var/log/unbound/unbound.log
Sep 06 13:56:43 unbound[498765:0] info: validation failure <fail03.dnssec.works. A IN>: signature crypto failed from 5.45.109.212
Sep 06 13:57:02 unbound[498765:0] info: validation failure <fail03.dnssec.works. A IN>: signature crypto failed from 5.45.109.212
Sep 06 13:57:23 unbound[498765:0] info: validation failure <fail04.dnssec.works. A IN>: no keys have a DS with algorithm RSASHA1-NSEC3-SHA1 from 5.45.109.212 for key fail04.dnssec.works. while building chain of trust
Cleanup
It only logs failures so could be left on so it always catches a situation. To disable it edit the pi-hole.conf file and either set val-log-level to 0 (which means off) or comment the line out. Then restart Unbound the same way as earlier on.
If you wish to clear out the log file use the command:
sudo truncate -s 0 /var/log/unbound/unbound.log
