instead of lighttpd
, or there is some other aspect of your install that is customised) - please use the Community Help category.*
No non-standard elements. Installed pihole on Synology container management.
Should be able to start using pihole immediately without any hiccups
Can log in to pihole interface but nothing works. It isn't blocking. I suspect there is something wrong with networking.
https://tricorder.pi-hole.net/3Wt71ARJ/
More Information:
I have also tried to configure Macvlan but everything I set it the manage my pihole container, I am unable to addess the pihole interface when using the IP address. Not sure what is wrong.
I am a noob, any help is appreciated. Thanks!
