Unable to Drill Down in Network Overview
In the previous release one was able to drill down on an IP address in the Network Overview section. In the beta the drill down seems to be not working. Is this by design or a bug?
This is a bug. I'll check it out once I'm through with all the posts that came in today.
Indeed, IP address sorting is broken as we support multiple IPs per device in the same row now.
The question that arises not: How to sort by multiple IPs in the same row?
We could sort by the first IP for each device, but is this intended behavior?
Or shall we disable the ability to sort by IP altogether?
Input from others would be appreciated, @jfb @PromoFaux @DanSchaper.
Possible fix for the sorting issue
https://github.com/pi-hole/AdminLTE/pull/1135
If sorting is offered for IP, then it should be the first IP listed for that Hardware address.
This re-installs clickable links for all shown IP addresses:
https://github.com/pi-hole/AdminLTE/pull/1136
@cipherwar This has now been reviewed and merged into the beta release.
